Abbas Raza
Rep Power: 0 ![]() |
Hello all, I'm fairly new to CFD and still trying to get a hang of it. I have performed this simulation and convergence criteria were all set to default. Does this iteration graph show that my solution is converged?
Svetlana Tkachenko
Rep Power: 14 ![]() |
Hi raza111
1. Is this the first time you are running a CFD simultion? 2. Your continuity has converged to the value of 1e-1. You do not need to run the simulation any further, this is unlikely to improve convergence. 3.The 1e-1 level may be insufficient. It is often needed to converge to 1e-4 or lower. Please do mesh independence study. 4. I think this FAQ is relevant: https://www.cfd-online.com/Wiki/Ansy...gence_criteria Svetlana |
#3 | |
2) 80 Iterations is not really a lot. I rarely see simulations meeting the convergence criteria with this little amount of iterations, even with good initial values. 3) The graphs still indicate global convergence behaviour, so my advice would be to let it run further. 4) There is really no need to abort the simulation at this point since you are likely to improve result accuray with further iterations. 5) Always check for a flow quantity of interest, not just the residuals, to judge the level of convergence. |
Svetlana Tkachenko
Interesting note that it may converge in the future which I thought it wouldn't (your point number two). Thank you for this correction. I hope the author can check and confirm this.
convergence, iterations |
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
In the case of convergence | aja1345 | FLUENT | 1 | July 31, 2015 03:58 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
Convergence of CFX field in FSI analysis | nasdak | CFX | 2 | June 29, 2009 01:17 |
Defect correction and convergence | ganesh | Main CFD Forum | 4 | June 30, 2006 14:20 |
