Using a Parameter Set with Fluent Meshing Workflow |
July 5, 2019, 10:26 |
Robin
Rep Power: 7 |
I wanna use the Fluent Meshing Workflow with Workbench instead of Ansys Meshing to generate my mesh.
In meshing mode the geometry is not taken from a geometry element, so I don't know how to use Parameter Sets. If I link the geometry to my Fluent (with Fluent Meshing) object I can see it in the Outline View, but in the workflow I'm still asked to import a geometry. Is there a way to use the Parameter Set or do I have to use a UDF? Thank you! |
July 18, 2019, 06:06 |
Use of workflow is possible
Robin
Rep Power: 7 |
I found a way to use the Workbench with the watertight geometry workflow and SpaceClaim.
I had to activate the beta functionalities in the settings of Workspace and then connect the geometry box to the mesh of a Fluent Meshing box. Finally, I had to select the Mesh and activate "Use Workflow" in the properties of the mesh. |
ansys meshing mode, parameter set, waterthight geometry, workflow |
[ICEM] ICEM Scripting Issues | tylerplowright | ANSYS Meshing & Geometry | 33 | September 27, 2021 17:35 |
Custom Parameter Output in Fluent using Scheme | ishan_ae | Fluent UDF and Scheme Programming | 0 | April 13, 2018 11:02 |
Transfer named selections from SW to Fluent Meshing | the-sted | FLUENT | 0 | May 2, 2016 00:44 |
[ANSYS Meshing] Suggested workflow for cavity meshing | the-sted | ANSYS Meshing & Geometry | 0 | April 26, 2016 15:48 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
