Divergence detected in AMG solver: temperature |
June 23, 2019, 08:27 |
Mou Yan
Hello everyone,
I'm currently doing the 2D NACA 0012 Airfoil Validation Case: https://turbmodels.larc.nasa.gov/naca0012_val.html I created the mesh and set the case according to the website. But when I try to calculate it. Fluent will not calculate due to this error: Divergence detected in AMG solver: temperature Code:
iter continuity x-velocity y-velocity energy k omega time/iter Stabilizing pressure coupled to enhance linear solver robustness. Experiencing convergence difficulties - temporarily relaxing and trying again... Experiencing convergence difficulties - temporarily relaxing and trying again... Stabilizing temperature to enhance linear solver robustness. Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Error at host: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 2: floating point exception Error at Node 3: floating point exception Error: floating point exception Error Object: #f
I used the Hybrid initialization and coupled solution method (pressure-velocity coupling). I tried different Mach number, and I found out when I used Mach 0.3, the error has new information :turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 10 cells. And when I tried Mach 0.6, the case runs. So, my questions are:
Do you have any ideas? I will provide more information if it's needed. Thanks in advance. Mou |
June 24, 2019, 01:13 |
Rep Power: 18 |
Hi Mou,
The most likely cause is that the under-relaxation factor (URF) for that equation is too large. Reduce the URF and repeat the calculation. Please make sure the minimum orthogonal quality for the mesh is 0.01 (0.15 is better), the maximum skewness reported in Mesh > Quality is less than 0.93-0.95 A final possible cause of AMG divergence is incorrectly defined as boundary conditions. Hope this help, |
June 24, 2019, 03:05 |
Mou Yan
Hi ngoctm,
Thanks for the advice, after I changed the URF and it runs! Best regards, Mou |
April 9, 2024, 01:51 |
minjeongkim
Rep Power: 2 |
I am currently analyzing the fluid flow field of a multi-nozzle in three dimensions. However, the following error keeps occurring.
Divergence detected in AMG solver: temperature absolute pressure limited to 5.000000e+10 in 32400 cells on zone 2 turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 2150 cells Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Divergence detected in AMG solver: temperature Error at host: floating point exception ===============Message from the Cortex Process================================ Compute processes interrupted. Processing can be resumed. ================================================== ============================ Error: floating point exception Error Object: () Error at Node 2: floating point exception Error at Node 0: floating point exception Error at Node 1: floating point exception Error at Node 3: floating point exception Error: floating point exception Error Object: #f mesh quality is ------------------------------------------ Skewness min 2.5942e-07/max 0.40638 aspect ratio min1.0015/max 3.346 orthogonal quality min 0.84878/max 1. ------------------------------------------ I need advice. please help me.. thank you |
fluent |
Population Balance Modeling (PBM) - Ansys Fluent | chittipo | FLUENT | 164 | November 18, 2023 12:54 |
Divergence detected in AMG solver: temperature | raj_kumar | FLUENT | 1 | September 7, 2016 03:57 |
Fluidized Bed: Error: Divergence detected in AMG solver: pressure correction Error Ob | Mole89 | FLUENT | 5 | April 12, 2014 10:32 |
Divergence detected in AMG solver: temperature | otubaba | FLUENT | 7 | October 29, 2013 09:39 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
