June 17, 2019, 02:21 |
viscous dissipation in fluent
Mohammad Ahmadi
Rep Power: 7 |
Hi
I have 2 questions. 1- Is it possible to define viscous dissipation in laminar flow? 2- How can I obtain dissipation in Fluent? thanks |
June 17, 2019, 13:12 |
Lucky
Rep Power: 66 |
1. Yes. Turn on the energy equation and enable the viscous heat generation. If you are not referring to heat generation due to viscous effects but only the viscous losses in the momentum equation, those are always there in Navier-Stokes. You don't have to do anything. Just use the laminar model.
2. What do you mean by obtain? Like put it in your pocket? Or what? |
June 18, 2019, 01:04 |
Mohammad Ahmadi
Rep Power: 7 |
thank you for your answer.
I mean how can I measure viscous dissipation in fluent? |
June 18, 2019, 01:32 |
Rep Power: 15 |
I did this in OpenFOAM a long time ago.
In order to "measure" the effect of viscous dissipation, I chose an adiabatic boundary condition at the wall and ran the case twice. Do the same and you should then be able to see a slightly higher wall temperature using the dissipation option. Regards, Victor |
July 5, 2019, 12:56 |
#5 | |
Mohammad Ahmadi
Rep Power: 7 |
VISCOUS DISSIPATION | ROBERT | Main CFD Forum | 30 | May 29, 2019 05:21 |
Residuals and forces spiraling out of control before failing | edomalley1 | OpenFOAM Running, Solving & CFD | 3 | September 7, 2018 11:42 |
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
how does Fluent calculate the pressure and viscous force ? | e30.lsb | FLUENT | 7 | June 27, 2011 22:31 |
Viscous heat dissipation | muhammad asif | Main CFD Forum | 0 | July 25, 1998 05:00 |
