May 15, 2019, 05:02 |
shel conduction in Fluent
benyahia nabil
hello
I used fluent to study natural convection in cavity. In boundary condition, when considered shell conduction, what is the boundary conditions in that case at the outside of the walls? Best regard |
May 15, 2019, 11:29 |
Lucky
Rep Power: 66 |
Yes the boundary condition is applied on the exterior.
May 15, 2019, 18:41 |
benyahia nabil
thanks for your answer LuckyTran.
But I want to know when shell conuction is enabled, how it treats the condition in the other part (the second side), or we can set this condition. thank you |
May 16, 2019, 11:36 |
Lucky
Rep Power: 66 |
Let's say you have a fixed temperature boundary condition. I represent surfaces with |
Normally when you have a wall BC you have fluid| and you apply the boundary condition to this |. When you use shell conduction you have fluid|shells|, this bold | is where the thermal boundary condition is applied. So you would apply the fixed BC to this | and not the |. It should be apparent that the BC is not applied at | because then there would be no point in using shell conduction. |
Linux Fluent HPC parallel system check failed | saad3000 | FLUENT | 1 | January 8, 2021 03:34 |
Abaqus - Fluent Coupling WITHOUT MPCCI | s.mishra | FLUENT | 1 | April 5, 2016 06:47 |
Conduction and Convection Heat Transfer rate in Fluent Results | Onurozcan | FLUENT | 0 | January 14, 2016 12:39 |
Fluent Usability in Conduction problems | Randeep | FLUENT | 0 | January 12, 2007 03:51 |
Anistropic thermal conduction in Fluent 6.2 | Bharath | FLUENT | 0 | November 23, 2006 21:07 |
