Ansys Fluent 17.0 Expression
Like Tree2Likes
  • 1 Post By MKuhn
  • 1 Post By AlexanderZ
Old   May 7, 2019, 13:49
Default Ansys Fluent 17.0 Expression
u_k
u_k is on a distinguished road
In report definition i cannot create the expression. The option is freezed . Can some one please help me with this????......
Report Definitions -->New--->Expression
u_k is offline   Reply With Quote
Old   May 9, 2019, 06:22
Moritz Kuhn
MKuhn is on a distinguished road
As the Expressions are created from Report Defnitions, you have to create first a Report Definition (avarage temperature of a surface or volume). Than you can create an Expression like ReportDefinition1 * ReportDefiniont2 * 1000.
Mkalantar likes this.
MKuhn is offline   Reply With Quote
Old   May 9, 2019, 08:06
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
using User-defined -> Custom Field Function Calculator
best regards
u_k likes this.
AlexanderZ is offline   Reply With Quote
Old   May 9, 2019, 09:37
u_k
Thanks Mkuhn, yes i tried it just the way you have suggested. I created two report definitions i.e (area weighted average--Absolute pressure at inlet & outlet) and then i went to report definition to give an expression for their difference to calculate pressure drop but the option for Expression remains freezed but in version 18 and 19 its working just the way you said.
Old   May 9, 2019, 09:42
u_k
best regards
@alexander Z, thanks , can you please explain it a bit more? I mean how should i go for it for calculation of pressure drop i.e for taking pressure difference between inlet and outlet?
Old   May 9, 2019, 23:54
Alexander
as I said, make these first steps, than goto User-defined -> Custom Field Function Calculator and create an expression using your definitions
best regards
Old   May 10, 2019, 06:21
u_k
best regards
Thanks AlexanderZ, i have repeated these steps again but this expression option is still freezed or unavailable .
Old   May 13, 2019, 01:56
Alexander
create your expression in calculator
best regards
Old   May 13, 2019, 07:15
u_k
in calculator i can give the formula for the calculation of pressure drop but i want to give an expression for the subtraction of already created inlet pressure and outlet pressure report functions. which i tried as well but i dont know why it just didnt work. I might be getting it wrong. Can you please attach some of the screen shots if its possible.
Thanks in advance
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 04:34
Can you help me with a problem in ansys static structural solver? sourabh.porwal Structural Mechanics 0 March 27, 2016 18:07
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 13:07
ANSYS and ANSYS Fluent Field85 ANSYS 3 May 17, 2015 17:21
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 07:10
