April 17, 2019, 10:46 |
2D higly underexpanded jet
Gianmario Ledda
Rep Power: 7 |
Hi, I work for my master thesis and I must study an higly underexpanded jet due to an accidental release of methane from a pressurized pipe.
I try to work with a 2D geometry but I have different results from 3D to 2D geometry and I don't understand why. In 3d I have a result in according with the theory, meanwhile in 2D I'm not able to reach it. I use Fluent 18.2 I use a convergent nozzle, with a pressure inlet |
April 17, 2019, 11:11 |
Lucky
Rep Power: 66 |
What are we looking for?
The nozzle contours are different. Even if the contours are the same, you are doing a 2D slot versus (we can't see it but presumably) a 3D axissymmetric nozzle. Maybe an apples to apples comparison rather than an apples to elephant comparison would be more helpful? |
April 17, 2019, 11:31 |
Gianmario Ledda
Rep Power: 7 |
Tank you for the answer LuckyTran. I already fix the contours of the nozzle and now are the same, but my problem is the same. I have my 3D problem, but because I have a radial simmetry I decide to study the problem in 2D, and according with the theory the result must be the same that I have reached in 3D. So the theory says that I can study my problem in 2D and the velocity field must be similar to 3D image. But I'm not able to do this.
Do you think that I must study also my 2D problem like axissymetric? |
April 17, 2019, 11:57 |
Gianmario Ledda
Rep Power: 7 |
LuckyTran, I understand and solve my problem, thank you so much.
April 28, 2019, 05:18 |
akash gupta
Hello
I am working on CD Nozzle (2D Model) simulation in ANSYS Fluent- (real time project). The Inlet conditions are: Pressure =0.6mpa and Temperature = 588.6 k. Expected outlet Temperature is around 350 k. As I am trying to simulate in Fluent, after few iterations, I am getting a reverse flow on pressure inlet and pressure outlet and there is also a reduce in time step due to excess temperature change. How can I resolve these kind of errors that will help me to in the simulation. can you help me plz |
ansys 18.2, fluent 18.2, jet |
Acoustic Model of Slightly Underexpanded Supersonic Jet Not Working | ZNoel | FLUENT | 0 | March 9, 2018 18:09 |
How does the dissipation of a supersonic underexpanded jet depend on grid fineness | gauthamnarayan | Main CFD Forum | 1 | July 2, 2015 07:50 |
Re: Underexpanded jet BC | kiran | Main CFD Forum | 2 | December 26, 2010 12:17 |
problem with highly underexpanded free jet | Raaf | Phoenics | 11 | April 8, 2009 13:36 |
underexpanded jet | flozzermeister | Main CFD Forum | 0 | November 10, 2006 06:59 |
