Importing complex terrain
Like Tree1Likes
  • 1 Post By arnie333
Old   March 25, 2019, 13:07
Default Importing complex terrain
Joćo Silva
Joćo Silva is on a distinguished road
Dear fellow forumers,
I am currently doing my thesis that involves modelling a flow over a complex portion of terrain of the island of Madeira, Portugal.
For that, I am using Fluent, a software in which I only have basic knowledge.
So far, I am still in the phase of importing the x,y,z coordinates of the terrain. I am talking of about 2 800 000 points in a region with a length of 42km in the x direction and 52km in the y direction (easting, northing format).
I looked for the appropiate ways to arrange the data in a .txt file in order to import it to either space claim or design modeler but it is not working.
Which one would you recommend in my situation, space claim or design modeler? Can they even handle such a big ammount of points?
Do you have any suggestions?
In the link provided you can find the original file of data obtained from the Global digital elevation map.
You can also find the files with the data arranged to be imported in space claim and design modeler.
In the fourth file I altered the space claim file by relating all the values to a coordinate system with zero in the origin.
I thought the issue could be related to this as in the original file, the origin of the coordinate system (bottom left corner) was (312883.32m, 3599063,18m) because I am dealing with easting/northing coordinates.
Thank you very much for your help in advance.
https://we.tl/t-D2TrUsnMXy
Best regards,
Joćo Silva
Joćo Silva is offline   Reply With Quote
Old   March 26, 2019, 12:25
Arnie
arnie333 is on a distinguished road
Joao,
I think the following Youtube video will help you out..
https://www.youtube.com/watch?v=v1HlmuXUgdY
Not sure if your file is be too big though.
Can you not reduce the resolution at least 50% by removing every second point ?
Boa sorte and ocha la que tenhas resultado !
Arnie
Joćo Silva likes this.
arnie333 is offline   Reply With Quote
Old   March 26, 2019, 17:17
Joćo Silva
Arnie, I already saw that video and I am following the same procedure but it doesn't work.
I will keep trying. Thank you anyway!
Old   March 26, 2019, 17:18
Joćo Silva
I will try your suggestion of reducing the resolution!
Old   March 27, 2019, 00:48
Arnie
Joao,
I took your original .dat file (120MB) but used only the first ~40 points and it worked fine.
I would suggest reducing the file by 80% (i.e. only keep 1 of every 5 points) to try it out first.
When you copied it over to Excel, did you make sure that the precision (after the decimal point) was not truncated ?
Regards,
Arnie
Old   March 27, 2019, 09:55
Joćo Silva
Arnie, you did it on Design Modeler or space claim?
Old   March 27, 2019, 12:11
Arnie
Design Modeler
Old   March 27, 2019, 14:34
Joćo Silva
I was able to reduce the resolution from about 2800000 to 70000 points.
It is working now but I discovered that in my version of the software, the limit of imported points is 10000.
Do you have any idea if this has to do with the fact that it is a student version?
Old   March 27, 2019, 15:50
Arnie
Joao,
I don't know if the student version limits the number of imported points.
But the student version is going to limit your analysis to 512 000 elements too. I don't think this will allow you enough accuracy for your study/analysis to be particularly meaningful or accurate.
Arnie
[snappyHexMesh] adding layers on complex terrain surface in SHM potac OpenFOAM Meshing & Mesh Conversion 1 November 9, 2020 07:40
How to apply variabe roughness, e.g. to complex terrain? Fridolin OpenFOAM Running, Solving & CFD 3 August 12, 2020 16:09
[SOWFA] how to use terrainBlockMesher for meshing a complex terrain? Muhammad Omer Mughal OpenFOAM Community Contributions 11 June 6, 2016 01:39
Meshing complex terrain CFT123 FLUENT 0 March 13, 2015 04:19
[ANSYS Meshing] Complex terrain meshing egge24 ANSYS Meshing & Geometry 0 November 5, 2014 21:05
