Start plot again
Like Tree1Likes
  • 1 Post By racing_student
Old   March 19, 2019, 04:02
Default Start plot again
crinoid
crinoid is on a distinguished road
I am running a simulation in Fluent and plotting some variables meanwhile. In the first few iterations, the values I get are too high, so I can't see any difference in the evolution of the variables afterwards (the look totally flat).
How can I reset those plots? I've tried to close them, but when they reopen, the show the previous values too.
Thanks in advance!
crinoid is offline   Reply With Quote
Old   March 19, 2019, 07:09
robboflea is on a distinguished road
I think you may be able to reset them by resetting the residuals using the following TUI command:
/solve/monitors/residual
and then answering yes to the question. It should do the trick
Rob
robboflea is offline   Reply With Quote
Old   March 19, 2019, 08:19
Marius
racing_student is on a distinguished road
You could also set a maximum value for the y-axis
ama294 likes this.
racing_student is offline   Reply With Quote
Old   March 19, 2019, 08:58
Lucky
I don't know the command to clear the data during runtime. But closing Fluent and then reopening it will also clear plot data.
Old   March 21, 2019, 05:45
crinoid
Ok, thank you very much for your answers. I managed to do it with your tricks.
LuckyTran, that didn't helped... When I opened Fluent once again, the plot restarted where it had finished the last time with the previous data loaded.
Old   March 21, 2019, 09:32
Lucky
Residuals are stored in the case file. Monitors are not. When you said you were plotting variables I assumed you meant solution variables. If you restart the simulation then the residual plots stay and monitor plots are cleared.
Resetting residual statistics resets the residual plots but does not reset monitor plots.
Anyway now you have both answers and know how to reset a plot in the future.
Old   August 19, 2019, 13:22
Abdulaziz Abutunis
ama294 is on a distinguished road
Would you share the trick because I have the same issue and closing the Fluent to reset the plot is not practical?
Thanks
Aziz
ama294 is offline   Reply With Quote
Old   August 19, 2019, 14:01
Default Thanks
Abdulaziz Abutunis
This was a smart way to solve this issue. Thanks a lot
plotting
[Tutorials] Tutorial of how to plot residuals ! wolle1982 OpenFOAM Community Contributions 172 December 6, 2024 07:20
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Partition does not start on physical sector boundary!!?? immortality Lounge 1 December 8, 2013 16:04
Plot on a curve Monica FLUENT 1 July 11, 2012 01:24
Lets start the public domain CFD-Project! Heinz Wilkening Main CFD Forum 3 March 11, 1999 23:55
