mass flux v mass flow rate in fluent
Like Tree1Likes
  • 1 Post By alinik
Old   March 7, 2019, 11:10
Default mass flux v mass flow rate in fluent
ali
alinik is on a distinguished road
Hi all,
What is the difference between mass-flux boundary condition and mass-flow rate inlet boundary condition in fluent?
they seem to be similar
I am using fluent 19
Thanks,
alinik is offline   Reply With Quote
Old   March 7, 2019, 11:43
ali
apparently it does not make any difference according to my research.
Please correct me if I am wrong
Old   March 7, 2019, 12:35
ali
I found the answer to my own question. Thought I post it here, in-case someone else has the same question
If a total mass flow rate is specified, ANSYS FLUENT converts it internally to a uniform mass flux by dividing the mass flow rate by the total inlet area. If the direct mass flux specification option is used, the mass flux can be varied over the boundary by using profile files or user-defined functions. If the average mass flux is also specified (either explicitly by you or automatically by ANSYS FLUENT), it is used to correct the specified mass flux profile
THA SEANGHAI likes this.
fluent, mass flow rate bc, mass flux
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Mass Flow Rate in Fluent mhakimakbar FLUENT 2 April 22, 2016 14:12
Calculating mass flow rate at multiphase flows Kuslo187 OpenFOAM Post-Processing 1 August 21, 2015 19:11
Mass Flow Rate Error jallison FLUENT 1 May 16, 2011 17:22
How are the mass flux and mass flow rate defined? Miles Siemens 2 November 7, 2002 09:45
