choosin higher number of processes than actual number of cores |
February 26, 2019, 17:45 |
ali
Rep Power: 18 |
Hi, all,
What happens if I choose higher number of processes than actual number of cores on my machine to run fluent in parallel? Thanks, |
February 26, 2019, 19:35 |
Lucky
Rep Power: 66 |
It will launch that many processes. When you click calculate and it is iterating, it'll end up running slower since all the threads have to complete their task. The threads will wait on one another to finish before moving on.
February 27, 2019, 10:00 |
ali
Rep Power: 18 |
Thank you LuckyTran
So the most optimum case would be to have as many threads as the number of cores that I have. Correct? Because somewhere I heard that the number of cores is actually twice the number of processors. So if I have 8 cores, it means I can launch 16 processes on fluent. By your account, that is not correct. Am I right? |
February 27, 2019, 11:01 |
Lucky
Rep Power: 66 |
Note that what ppl call cpu/core/processor means a lot of things.
If you have a processor die/socket with 8 cores (an oct-core for example) and you have hyperthreading on you will have 8 physical processes + 8 virtual processes = 16 logical processes. So you will have 16 possible processor threads to which tasks can be assigned. You need to know your hardware to know whether hyperthreading is on or not. If you are using windows, go to task manager and performance tab and you can find out how many logical processes you have total. In win7 it shows how many logical processes there are (e.g. 16 if it is 8+8). In win10, it will tell you number of sockets, cores, logical processes. If you plan to do serious CFD calculations, hyperthreading should be off. But there are various reasons why hyperthreading might be on (for example, you never turned it off, or you cannot turn it off because you're not the admin). If hyperthreading is on and needs to stay on, then you should run on 16 processes to saturate the cpu. Last edited by LuckyTran; February 27, 2019 at 14:45. |
February 27, 2019, 12:10 |
Rep Power: 9 |
I think you can refer to the datasheet or Wiki-page of your processor to know the cores and threads that it handles. e.g.
https://en.wikipedia.org/wiki/Intel_Core |
February 27, 2019, 14:59 |
ali
Rep Power: 18 |
LuckTran,
That was the most comprehensive answer to my question. Thank you Roh, Thanks for sharing the info. That was very helpful |
Decomposing meshes | Tobi | OpenFOAM Pre-Processing | 22 | February 24, 2023 10:23 |
Inconsistencies in reading .dat file during run time in new injection model | Scram_1 | OpenFOAM | 0 | March 23, 2018 23:29 |
SigFpe when running ANY application in parallel | Pj. | OpenFOAM Running, Solving & CFD | 3 | April 23, 2015 15:53 |
foam-extend_3.1 decompose and pyfoam warning | shipman | OpenFOAM | 3 | July 24, 2014 09:14 |
[blockMesh] --> foam fatal error: | lillo763 | OpenFOAM Meshing & Mesh Conversion | 0 | March 5, 2014 11:27 |
