Axisymmetric geometry
Like Tree2Likes
  • 1 Post By LuckyTran
Old   February 18, 2019, 09:02
Default Axisymmetric geometry
Jacob
Mechand is on a distinguished road
Hello!
I am modelling a reactor using axisymmetric assumption. But since it is only half of the 2D geometry, so my question is, what values of mass flow rate should I specify at the inlet? Should it be the same value as for the 3D real reactor, or somehow modified?
Mechand is offline   Reply With Quote
Old   February 18, 2019, 09:05
Lucky
For axisymmetric cases you put the entire mass flow rate of the 3D thingy.
http://www.afs.enea.it/project/neptu...g/node1118.htm
Mechand likes this.
Old   February 18, 2019, 09:07
Jacob
I forgot to mention that the reactor has a cylindrical shape
Old   February 18, 2019, 09:10
Jacob
So I don't multiply it by 2*PI, or divide it, just simply the same value as for 3D case.
It's strange because 2D case has completely different results than 3D case. I have no slightest idea what could be the problem. Settings are all the same , geometry is simple 2D rectangular, 3D is a pipe.
Lucky
Yeah.. I edited my post. I gave you the instructions for regular 2D the first time.
Right. Don't divide by 2pi. Put the massflow through the entire 3D inlet. Fluent will divide by 2pi for you.
Mechand likes this.
Fill CAD Geometry voldemort Autodesk Simulation CFD 0 July 12, 2016 02:47
Import Deformed Geometry into Fluent lgamble FLUENT 1 February 25, 2016 14:59
[blockMesh] Trouble using blockMesh for axisymmetric geometry twinturbotom OpenFOAM Meshing & Mesh Conversion 1 February 8, 2016 21:59
finding torque in 2D Axisymmetric geometry( bivas108 FLUENT 0 February 21, 2013 03:02
Problem Importing Geometry ProE to CFX fatb0y CFX 3 January 14, 2012 20:42
