Residual diverrgence / mesh quality
Like Tree2Likes
  • 1 Post By sufjanst
  • 1 Post By MKuhn
Old   February 18, 2019, 05:33
Default Residual diverrgence / mesh quality
Andrea
Andrea159357 is on a distinguished road
Hello, i'm really struggling understanding how fluent works.
I'm running a thermal fluid problem with
different meshes but i cannot reach convergence.
The first mesh is obtain with cutcell and even though max skew is 0.992 and max asp Ratio is 67, i improved quality in fluent and i reach perfect convergence of FLUID equations solution and monotonous behaviour of residuals. Then i turn on ENERGY equation and everything blows up. I got message of " Limited temperature in xxx cell of 1 K " and " Limited temperature in xxx cell of 5000 K ".
I thought was for bad quality mesh so i remade it.
The second one is a normal all TET mesh + inflation layer.
This one has max skew 0.88 and max asp Ratio 123. (COOL i thought).
Though even the fluid solution can't reach convergence.
How is it possible?
Andrea159357 is offline   Reply With Quote
Old   February 18, 2019, 05:39
sufjanst is on a distinguished road
I had a similiar problem. For some reason, fluent sets the fluid temperature to 1K. Of course, the simulation will crash.
Fix: Just activate the energy equation and patch your flowfield to a temperature of 300K (or whatever your conditions are). That should do it.
Andrea159357 likes this.
sufjanst is offline   Reply With Quote
Old   February 18, 2019, 06:08
Andrea
already done. I patched all domain to 1000 K (solution is around 1050 K ), first 30 iteration residual converge to e-9. Afterwards it starts growing unitil it explode.
I stop the solver to the min residual i got and solution is good. But i was wondering why after 30 iter blows up but the thing is why with a mesh better than the previuos one even the fluid can't reach convergence?
how fluent works?
Old   February 18, 2019, 06:18
That's indeed pretty strange. Can you share some information on your problem and your case setup?
Old   February 18, 2019, 06:22
Andrea
YEAH. What do you need?
It is not a set up probelm since i already run a simulation with a slightly different geom and it worked perfectly.
Old   February 18, 2019, 06:40
Moritz Kuhn
MKuhn is on a distinguished road
It is possible to use the case set up from the previous simulation? (read mesh --> replace mesh --> discard data). If divergence occurs again then it should a mesh problem. Stop the solver after the energy begins to grow up. Locate the cells where the temperature is out of your expected range. An inproper face match between to different cell regions could be the problem as well (where you assume a heat flux, but there is no heatflux possible because of inproper face match).
MKuhn is offline   Reply With Quote
Old   February 18, 2019, 07:03
Andrea
I did like you said, thats why it is not a set up problem but is a mesh one. I even did what you said, i mark and adapt those cell but nothing ggod happened, so i remash.
The cells with high skew are not in a single region but scattered all around the geom (15/20 cell) and they influence the cells around.
With an improper face match U mean between cells or between domains, e.g. solid and fluid?
Old   February 18, 2019, 07:07
Moritz Kuhn
I mean domains, where you have to connect different volumes in your CAD-Model.
Old   February 18, 2019, 07:26
Andrea
that's possible. I used share topology in Spaceclaim but maybe i generate connection using "find contact" in meshing that screw up everything.
Thanks a lot for your help, i check now.
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
Floating point exception error lpz_michele OpenFOAM Running, Solving & CFD 53 October 19, 2015 03:50
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
calculation stops after few time steps sivakumar OpenFOAM Running, Solving & CFD 7 March 17, 2013 07:37
