February 12, 2019, 13:53 |
wall adiabatic thermal condition
Weiqiang Liu
Rep Power: 9 |
Hi all,
I have a question about how fluent set adiabatic wall condition. I have a straight channel without solid part. I want to set the wall adiabatic to the environment. Namely, there is no heat loss from the computation domain to the environment. In the thermal condition panel of the wall, there are some options like : heat flux, constant temperature, convection, radiation, mix. my question is if I set heat flux or convection coefficient to 0, how does the heat produced on the wall transfer to the inner gas phase. As far as I am concerned, zero heat flux on the wall means there is no heat transfer on the nodes of the wall. Therefore there is no way, the heat can be transported from the wall to the inner gas mixture. Am I misunderstanding something? Can anybody give me some hints? thanks very much weiqiang |
February 12, 2019, 14:01 |
Lucky
Rep Power: 66 |
You can use either a heat flux of 0 or a convection coefficient of 0 (but a heat flux of 0 would be slightly better for numerical reasons).
And yes no heat flux means there's no heat flux which means there's no heat transfer because there's no heat flux. There is no wall, so there is no heat produced on the wall. It is meaningless to talk about what heat is being generated in another universe. But in your simulation, you have perfect control over the heat flux. It matters not where this heat comes from, you can set it to any mythical value you like. |
February 12, 2019, 17:48 |
#3 | |
Weiqiang Liu
Rep Power: 9 |
February 13, 2019, 05:06 |
Moritz Kuhn
Rep Power: 17 |
heat flux of 0 means there is no heat flux between your wall and your environment (where is no mesh), not that there is no heat transfer between your fluid and your solid wall. If you are interested in the heat transfer between fluid and wall, the best way is to model the solid mesh as well. Another possiblity is to use shell conduction for the wall instead of a solid mesh, but I'm not sure about the accuracy. Maybe LuckyTran knows more :-)
February 13, 2019, 07:48 |
Lucky
Rep Power: 66 |
You still can have surface reactions. You don't need a solid mesh for this.
February 13, 2019, 11:42 |
#6 | |
Weiqiang Liu
Rep Power: 9 |
February 13, 2019, 11:44 |
Weiqiang Liu
Rep Power: 9 |
February 13, 2019, 11:57 |
#8 | |
Lucky
Rep Power: 66 |
You need a solid mesh when you want to model the heat conduction process inside the wall. Or you have heat generation inside the wall from some other magical process. Surface reactions, don't happen inside the solid. They happen on the surface which can be modeled by.... surface reactions! Voila! These have nothing to do with the interior of the solid. I can't tell from your comments whether or not you need to do a solid mesh or not for your entire problem. But based on surface reactions alone.. no you don't need it (yet). But who knows... Maybe you do want to study the interaction your domain with the andromeda galaxy... You haven't told us. |
February 13, 2019, 13:03 |
#9 | |
Weiqiang Liu
Rep Power: 9 |
you might ask why I just use default value in fluent database. the reason is fluent database valued don't yield very reasonable results. like the temperature is too high or the surface coverage of species is not consistent with literature. after a lot of efforts and failures, I started to think is it because my boundary condition is not right. I don't have solid domain in my case and the wall is set as adiabatic. I am wondering if the heat flux is 0. How can the heat generated on the surface be transported to inner gas phase? |
February 14, 2019, 02:58 |
#10 |
Moritz Kuhn
Rep Power: 17 |
How is the heat generated in your wall? In Fluent you have the possiblity to define a Heat Generation Rate in W/m³ for the wall with a defined Wall Thickness. This is also possible with an adiabatic wall where the heat flux is 0 to the andromeda galaxy.
February 14, 2019, 09:51 |
#11 |
Weiqiang Liu
Rep Power: 9 |
yes, but I don't have a wall thickness in my case.
February 14, 2019, 09:55 |
#12 |
Moritz Kuhn
Rep Power: 17 |
But in reality every channel has walls with a certain wall thickness. And this is only one click in the boundary conditions in Flunet, you can switch it on and off, you do not have to setup a new mesh.
February 14, 2019, 10:37 |
#13 |
Weiqiang Liu
Rep Power: 9 |
do you mean I need to set a wall thickness in fluent even though I don't have wall mesh in my model?
February 14, 2019, 10:56 |
#14 |
Moritz Kuhn
Rep Power: 17 |
yes try it if you want to model the heat exchange betwenn the wall and the fluid. For this you have to define a solid material in fluent, even if you don't have solid mesh. Switch shell conduction on, if you are also interested in the heat conduction along the tube (planar direction) and not only in the normal direction of you boundary.
Wall thickness and wall mesh are different things. You can model a tube wall using solid mesh or via defining a wall thickness without solid mesh. You can also combine boths e.g. having a wall mesh and defined wall thickness to consider the coating of the wall. For more details and limitations please refer to the Fluent User's Guide. |
February 14, 2019, 11:03 |
#15 | |
Weiqiang Liu
Rep Power: 9 |
adiabatic, zero convection, zero heat flux |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 10:00 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
[ICEM] Export ICEM mesh to Gambit / Fluent | romekr | ANSYS Meshing & Geometry | 1 | November 26, 2011 12:11 |
Deformation of wall by temperature condition | Jay | FLUENT | 0 | April 14, 2007 18:06 |
