VOF Steam condensation
Like Tree1Likes
  • 1 Post By CFD-fellow
Old   January 22, 2019, 06:47
Default VOF Steam condensation
Andrea
Andrea159357 is on a distinguished road
Hello, i'm trying to analyze a condensation process in a pipe line using VOF mixture model but i got some problem understand how it works. I set Fluent as this tutorial said, https://www.youtube.com/watch?v=rRsdQC20NvA, exept for operationg pressure that is P = 8 [bar] and saturation temperature Ts = 443.15 [K].
T inlet = 473.15 [K] where water vapor density is 3.8314 (heated steam). When i set material, i defined water liquid and water vapor but at what condition? I mean, water liquid is not really a problem; i defined all coefficients at saturation temperature and pressure.
Different story is for water vapor; do i must defeine density at saturation or in heated condition?
Andrea159357 is offline   Reply With Quote
Old   January 30, 2019, 07:02
Behrooz Jamshidi
CFD-fellow is on a distinguished road
I think defining density as a linear function of temperature is a good idea.
Andrea159357 likes this.
CFD-fellow is offline   Reply With Quote
Old   March 8, 2019, 09:17
Default Condensation of steam in subcooled water
JIBIN Y GEORGE
jibinyg is on a distinguished road
I am also dealing with the same problem of steam condensation in water with vof multiphase model. But now as the iteration progresses, the steam keep growing in upward direction(-g) opposite to the direction of water.
Have you used any udf for condensation model?
Any help to this problem will be great thing.
Thanks in advance.
jibinyg is offline   Reply With Quote
Old   March 19, 2019, 15:19
Andrea
No, i didn't use UDF for condensation but you can use it. I ran the model with fluent condensation model just for a qualitative test. if you need really accurate results it's better you write your own udf
Old   March 19, 2019, 15:20
Andrea
For vapor model i think i should have use equation of state.
vof
steam condensation on water film ali72p CFX 3 July 29, 2018 08:04
steam condensation bubbly flow Dragonuser CFX 2 November 25, 2014 05:09
steam condensation Dragonuser CFX 9 November 14, 2014 07:12
Steam condensation on wall Dinesh Yadav Fluent UDF and Scheme Programming 0 April 12, 2014 04:39
superheated wet steam (avoid condensation in a nozzle) Ralf Schmidt FLUENT 0 August 11, 2009 12:55
