Can we use fluent to simulate heat transfer in a solid body?(without fluid)
Like Tree4Likes
  • 2 Post By LuckyTran
  • 1 Post By LuckyTran
  • 1 Post By AlexanderZ
Old   January 18, 2019, 13:56
Question Can we use fluent to simulate heat transfer in a solid body?(without fluid)
Roh
Roh is on a distinguished road
Guys,
I'm thinking to model/simulate heat transfer in a solid body. Is fluent capable of doing it? or fluent just simulate heat transfer between fluid-solid?
If fluent is capable of simulating heat transfer in solid bodies, how can I do it? tried to find any clue but my efforts have failed so far.
Roh is offline   Reply With Quote
Old   January 18, 2019, 14:11
Thumbs up
Roh
Found something:
youtube.com/watch?v=oCntLSAWEVo
Is it a valid tutorial?
Old   January 18, 2019, 14:30
Lucky
Yes Fluent does this. Just turn on the energy equation. Assign the cell zone as a solid. You still need to choose a flow model (i.e. laminar) that is valid with an energy equation (choosing inviscid doesn't work). Other than that, it is straightforward if you know how to do anything in Fluent.
Roh and racing_student like this.
Old   January 22, 2019, 04:35
Roh
I was trying to find any technical/application note of Fluent about heat transfer in solid.
Found this:
https://www.scribd.com/document/2459...8-HeatTransfer
And
http://www.afs.enea.it/fluent/Public.../PDF/chp11.pdf
In page 6 you can see this equation:
On the LHS of the equation, the convective is zero then on the whole LHS is zero. On the RHS we don't have source term and then Fluent just solve conduction term for our field. Is it right? kinda Fourier's law. right?
Another question, Why cannot I find many thing about heat modeling of solids in fluent? e.g. you said we need to choose laminar for this job but where can I find this note?
Old   January 22, 2019, 10:00
Lucky
Yes 11.2-11 on pg 6 is what Fluent solves in solids. It is a generalization of the canonical heat diffusion equation for moving solids. Fourier's law is the 1st term on the RHS. If the velocity is zero only the 2nd term on the LHS is 0, you still have the unsteady term.
You have to choose a viscous model in Fluent, you cannot turn them off. You need an energy equation. You can find this out in a few seconds in Fluent by clicking buttons. There's no need to spend 5 minutes reading it in any document.
Also before you click the calculate button it might be helpful to freeze the flow solver.
Roh likes this.
Old   January 22, 2019, 21:22
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
there is nothing special with simulation of heat transfer in solid bodies.
1. apply different materials to your zones
2. switch on energy equation
3. switch off flow equations
4. type in console following command
mesh m-z s-i-b
that's it
best regards
Roh likes this.
AlexanderZ is offline   Reply With Quote
Old   January 23, 2019, 03:08
Question
Roh
Originally Posted by AlexanderZ View Post
3. switch off flow equations...
I will do it as said in this post:
How to turn off flow solver in fluent
Is it okay?
And I think disabling or enabling the flow equations don't make any change and just help to have a quicker solution. Is it right?
mesh m-z s-i-b
that's it
As said here:
Divergence Problem Conjugated Heat Transfer
I think it's JUST for creating shadow. I have just one material. thus don't need it currently. Am I right?
Previosly I have solved my fluid problem and I exported the temp. profile and importing it for my heat transfer problem. I guess this appraoch helped to have a quicker solution because the solver doesn't need to solve aditional equation (energy equation in solid) for each iteration.
Old   January 23, 2019, 09:51
Lucky
Yes, follow that post for how to turn off the flow equations.
I have no idea why the console command mesh blah blah blah was recommended.
Old   January 24, 2019, 00:49
Alexander
yes, this command creates shadows between zones with different materials
best regards
No heat transfer between solid and fluid regions lilweasel STAR-CCM+ 3 October 14, 2016 15:36
Heat transfer between solid rotating and stationary fluid domains DCSERE CFX 2 November 17, 2015 04:43
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
No results for solid domain Gary Holland CFX 10 March 13, 2009 04:30
Conjugate Heat Transfer between fluid and solid Li Yang Main CFD Forum 8 March 27, 2004 12:05
