Calculate Thrust
Like Tree1Likes
  • 1 Post By LuckyTran
Old   January 14, 2019, 11:48
Default Calculate Thrust
Andreia
andreia_melo is on a distinguished road
I'm simulation a valveles pulsejet and i want to know the thrust, i read about this but i have some questions:
-In cfd-post it is possible to know the force at the exit but can i assume that force as being the thrust? I dont find any information on how this force is calculated by Fluent.
-I have this equaion thrust=massflow*Ve+(pe-p0)*Ae, if a use this formula the pe is the static or the total pressure ate the exit? And i'm doing a 2d simulation should i pass the mass flow to a 3d since it is not equal?
andreia_melo is offline   Reply With Quote
Old   January 14, 2019, 12:21
Lucky
The force is the integration of pressure and shear forces (probably negligible) at the boundary. It is not the thrust.
Pe is the exit static pressure.
Sorry I can't understand your last question. Just do the bookkeeping. Mass flow is going to come from a velocity and exit area also.
andreia_melo likes this.
Old   January 14, 2019, 12:24
Andreia
Thank you so much for your reply, it was really helpful!!!
Thrust Coefficient vs. Drag Coefficient m_ridzon Main CFD Forum 7 April 24, 2018 13:01
FlatWave Velocity as a function of Thrust dbalan STAR-CCM+ 2 April 11, 2018 21:53
calculate friction factor & nusselt number soheil1991 FLUENT 3 March 11, 2017 10:30
calculate velocity difference helly OpenFOAM Post-Processing 0 June 21, 2016 09:49
Propeller Thrust mahdisajjadi FLUENT 1 December 1, 2014 21:24
