January 13, 2019, 23:02 |
Improve the performance of RAM capacity
Angel Penev
Rep Power: 10 |
Hello guys and happy new year. I would like to ask one interesting question, about the hardware for Fluent. I was updating my computer before one week with more RAM from 8GB to 24GB, so I improved the performence. But the main problem is when I solve the model (calculate) the computer isn't use the whole capacity of RAM. I compare before, because when I had 8GB of my stationary PC the loading was 100% and now is only 35%. Is there option to use the whole capacity of RAM in the time of calculations. Thank you!
January 13, 2019, 23:08 |
Lucky
Rep Power: 66 |
It only uses as much RAM as it needs. But going from 100% RAM load (which probably means it was thrashing/swapping onto the hard drive) and going to <100% RAM load is very good and you should already be seeing a huge improvement.
RAM capacity doesn't affect RAM bandwidth so you won't see any speed improvement by upgrading to more RAM even if you add 100TB of RAM. |
RAM configuration for CFD performance | donminoti | Hardware | 1 | February 1, 2017 14:03 |
Insufficient RAM for Intel XEON E5-2699 v4 | alexp88 | Hardware | 4 | January 2, 2017 04:18 |
Calculation of gradient only for subset of cells to improve performance | elmo555 | OpenFOAM Programming & Development | 0 | July 11, 2016 09:35 |
mother board and ram amount. | zero_custom | Hardware | 4 | January 4, 2016 16:27 |
New workstation for different usage scenarios - CPU and RAM | natem | Hardware | 6 | August 7, 2013 02:47 |
