December 21, 2018, 07:27 |
Quick reading Boundary conditions
sunil
Rep Power: 14 |
Hi All,
I am solving conjugate heat transfer problem where my mesh count is around 30 million. I am having different cases with slight change in mesh. If I want to apply same boundary conditions for all the cases currently I am using file/read/name.bc command but it is taking more than 4 hours to execute. Please suggest me any quick way to assign saved boundary conditions to different case file. (replace mesh is also taking longer time) Regards, Sunil
Regards, Sunil |
December 21, 2018, 11:05 |
Lucky
Rep Power: 66 |
You're overthinking it. Use the modify/boundary-conditions to assign them to each case
January 1, 2019, 05:00 |
sunil
Rep Power: 14 |
Hi LuckyTran,
Yes you are right, but with the present method it is taking longer time so I started searching an alternative. Regards, Suneel |
January 1, 2019, 11:35 |
Lucky
Rep Power: 66 |
All the settings are stored in the .cas file, which if saved in ascii format is a giant text file. Opening each and every .cas file with a 30 million cell mesh will take time...
boundary condition |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Problem with SIMPLEC-like finite volume channel flow boundary conditions | ghobold | Main CFD Forum | 3 | June 15, 2015 11:14 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
