UDF Parabolic 2D Velocity Profile Issue
Like Tree1Likes
  • 1 Post By LuckyTran
Old   November 27, 2018, 13:43
Default UDF Parabolic 2D Velocity Profile Issue
chrislyn is on a distinguished road
I am trying to specify a fully developed velocity at the inlet of my gradual expansion diffuser. The UDF is below.
udf_parabolicinlet.c
UDF for specifying a steady-state velocity profile boundary condition
#include "udf.h"
DEFINE_PROFILE(inlet_x_xyvelocity, thread, index)
real x[ND_ND];
real y;
face_t f;
begin_f_loop(f, thread)
F_CENTROID(x,f,thread);
y = x[1];
F_PROFILE(f, thread, index) = .21 - y*y/(.002*.002)*.21;
end_f_loop(f, thread)
I plotted the equation in MATLAB and got a nice parabolic profile. However, whenever I run this case, I do not get a smooth graph. I get the graph attached.
The steps I follow are:
Write Code...save with file extension ".c"
Interpret it in Setup
Use it as the u component of the velocity inlet boundary condition
Run
Check Velocity Profile
Does anyone know what may be happening here?
chrislyn is offline   Reply With Quote
Old   November 29, 2018, 15:45
Lucky
To get a smooth curve, you simply need more points. Two things to consider:
Make sure your mesh is fine enough so that the curve appears smooth (it will always be jagged as shown).
How do you produce this plot? Using a line probe or what? Check the settings.
Better just, just plot the full velocity field and look at it and see if it makes sense.
chrislyn likes this.
Old   December 11, 2018, 13:11
Thank you so much! The mesh was too coarse in the initial run. Once I ran a mesh independence test, the profile looked how it was supposed to.
fully developed inlet, udf
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 07:25
Parabolic velocity profile in 3d with UDF mmk3818 Fluent UDF and Scheme Programming 1 August 21, 2016 19:35
How to define a parabolic velocity inlet of particles with UDF zumaqiong FLUENT 2 February 22, 2010 10:46
Logarithmic velocity profile cfdworker Fluent UDF and Scheme Programming 0 April 23, 2009 20:09
udf for velocity profile in a geometry having two inlets shubham208011 Fluent UDF and Scheme Programming 0 April 6, 2009 16:13
