Why is Pressure Recovery less than 1 for a smooth wall subsonic compressible flow |
November 25, 2018, 12:27 |
MWRS
Rep Power: 8 |
Wall roughness is set to zero. Then why is total pressure in outlet lower than inlet for a compressible flow?
I have simulated a simple diverging pipe. What exactly is decreasing the total pressure for a smooth pipe? |
November 25, 2018, 12:34 |
Lucky
Rep Power: 66 |
Do you still have a wall? I.e. no slip?
Smooth is a hydraulic term meaning that the wall roughness is small relative to a specific length scale. A smooth wall does not mean there is no friction (it just means there is no roughness). There will be a total pressure drop. Even if you had slip walls, you still have a viscous flow (navier-stokes) and there would still be a small drop in total pressure. |
November 25, 2018, 12:35 |
MWRS
Rep Power: 8 |
yes i have no slip
November 25, 2018, 12:36 |
MWRS
Rep Power: 8 |
so how would there be a small drop due to viscous flow in a no slip condition?
November 26, 2018, 13:05 |
Lucky
Rep Power: 66 |
The fluid has a velocity going into the diffuser. At walls, because of the no-slip condition (for both smooth and rough walls) the fluid adopts the velocity of the wall (presumably 0 m/s). Hence the fluid loses some momentum and this manifests as a total pressure drop.
Even if you have slip walls where there is no frictional force induced by the walls. The area is diverging and because of this you have velocity gradients which gives rise to viscous forces. In a newtonian fluid, wherever you have velocity gradients, you have viscous forces. |
November 26, 2018, 13:06 |
MWRS
Rep Power: 8 |
Many thanks !
Problem with an old Simulation | FrankW | CFX | 3 | February 8, 2016 05:28 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 09:16 |
Pressure contours in two compressible phase flow | Hershey | Fluent Multiphase | 1 | June 6, 2014 08:41 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 01:00 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 06:13 |
