Fluent meshing skewness vs Fluent skewness
Like Tree1Likes
  • 1 Post By Jiricbeng
Old   November 8, 2018, 09:53
Default Fluent meshing skewness vs Fluent skewness
Jiri
Jiricbeng is on a distinguished road
I created mesh in Fluent meshing (19.2) and checked skewness to be 0.971. I imported this mesh into Fluent (19.2) where there was warning the skewness is 1 !
I struggled with this also in ANSYS Meshing: in ANSYS meshing skewness was 0.98 and after importing into Fluent it was higher 0.99.
What is the reason Fluent shows another skewness (usually higher) than in meshing? How shall I be sure about mesh parameters before importing to Fluent?
Jiricbeng is offline   Reply With Quote
Old   November 14, 2018, 03:05
Jiri
I figured out the reason: parallelization. Parallel distribution leaded to skewness 1, serial mode leaded to the same skewness as in the Fluent meshing - 0.971.
BlnPhoenix likes this.
Old   January 10, 2019, 11:19
Jiri
Well, I came across a case where even in serial mode was quite different skewness than in meshing. Parallelization does not have to be the answer.
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
[ICEM] How can i reduce the skewness in this meshing??? gnut1989 ANSYS Meshing & Geometry 2 January 6, 2015 06:03
[Other] Equivalent of -wait command for fluent in meshing software ferroburak ANSYS Meshing & Geometry 0 August 29, 2014 04:34
Problem in using parallel process in fluent 14 Tleja FLUENT 3 September 13, 2013 11:54
problem in using parallel process in fluent 14 aydinkabir88 FLUENT 1 July 10, 2013 03:00
