Asees Aamir
Rep Power: 7 ![]() |
I was trying to use GPU for solving pressure, x-mom and y-mom equation. But I do not understand the parameters asked to be tuned by FLUENT.
I need help to understand >Termination criterion, >Solver, >Max Number of cycles, >Coarsen by size, >pre-sweeps, >post-sweeps and >smoother What do they mean and what should be their default values? Console is pasted here for ref: > solve/set/amg-options/amg-gpgpu-options /solve/set/amg-options/amg-gpgpu-options> pressure x-mom y-mom /solve/set/amg-options/amg-gpgpu-options> pressure Enable on GPGPU? [no] y Termination criterion [0.1] Solver (FGMRES PBICGSTAB AMG) ["FGMRES"] Max number of cycles [20] Coarsen by size [2] Pre sweeps [1] Post sweeps [1] Smoother (ILU GS JACOBI) ["JACOBI"] |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
These are the settings for the multigrid solver itself. It is not GPU specific, even in regular cpu solver, the AMG has the same parameters. You probably don't need to tune any of them. Better yet, if you don't know what each of these are, don't touch them! Leave them alone! The defaults are fine. If you understand what the AMG solver is/does, the names of these parameters are quite obvious / well-correlated. If you have to ask, then don't touch!
If you want to see what these do, don't play with it in GPU-land. Play with it in CPU-land. |
fluent - parallel, gpgpu acceleration |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 02:48 |
SIMPLE Algorithm Finite Difference Equations: how to discretize and solve? | DA6righthand | Main CFD Forum | 0 | August 3, 2015 12:12 |
Which equations are solved by rhoCentralFoam, rhoSimplecFoam and sonicFoam? | gamma_user | OpenFOAM Verification & Validation | 1 | April 19, 2015 12:13 |
Coupled Solution of the RANS turbulence equations | sfigato | OpenFOAM Programming & Development | 0 | September 14, 2014 08:59 |
Equations solved for multiphase | delaneyluke | CFX | 2 | May 5, 2010 06:42 |
