Pressure inlet vs. Velocity inlet
Like Tree2Likes
  • 1 Post By LuckyTran
  • 1 Post By Time4Tea
Old   October 31, 2018, 15:58
Default Pressure inlet vs. Velocity inlet
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
Consider an incompressible pipe flow,
How can I ensure that these combinations give the same results:
1. Pressure inlet + Pressure outlet.
2. Velocity inlet + Pressure outlet.
hamed.majeed is offline   Reply With Quote
Old   October 31, 2018, 16:22
Lucky
They are much pretty guaranteed not to.
With a pressure inlet you impose a uniform stagnation pressure. The velocity profile is more or less guaranteed to be non-uniform except for very exceptional cases.
With a velocity inlet you impose a uniform velocity, and here you are pretty much guaranteed to get a non-uniform pressure profile. Again, except for very very exceptional cases.
Time4Tea likes this.
Old   November 2, 2018, 15:25
Lee Strobel
Time4Tea is on a distinguished road
To add to what LuckyTran said:
A pressure-inlet is going to vary the velocity/mass flow to achieve the specified total pressure. A velocity-inlet is going to do the opposite and vary the total pressure to achieve the specified velocity.
If you do option #1; measure the average velocity on the inlet; and then apply that to the same geometry with option #2 (as a uniform velocity), you should get the same average total pressure on the inlet as in option #1, but, the distributions will be different (unless you save the velocity profile from case #1 and apply that in option #2, which would probably be the best way to achieve what you want).
hamed.majeed likes this.
Time4Tea is offline   Reply With Quote
Old   November 4, 2018, 09:28
Maddin is on a distinguished road
It's possible (with other software) - you have to map the profile of the "other" boundary condition you want.
Run pressure inlet and write the velocity profile of the inlet and then map this profile to the velocity inlet condition to have the same pressure profile should work.
For quick simulations I prefer velocity inlet, for deep dive action the pressure inlet (to run a constant pressure difference).
Maddin is offline   Reply With Quote
Pressure problems with inlet variable velocity jaimesdiegop CFX 2 September 1, 2016 03:31
Pressure Outlet Guage pressure Mohsin FLUENT 36 April 29, 2016 18:16
Pressure inlet vs outlet position, transient, time dependent pressure and gravity silent2608 FLUENT 0 February 6, 2016 11:19
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 05:43
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
