October 27, 2018, 15:41 |
See effect of gravity
Hamed Abdul Majeed
Rep Power: 14 |
If we turn on gravity in Fluent it calculates for modified pressure and the "absolute pressure" does not show the effect of gravity.
How to do that in Fluent! What I do now is to define a custom field variable P = absolute pressure + (density*gravity*mesh_y) I plot P and it gives me the require pressure drop inclusive of the gravity effects! Is there an easier way to do this in Fluent post-processor? Thank you. |
October 27, 2018, 21:29 |
Lucky
Rep Power: 66 |
No not really. The easiest way is to use a custom field function like you've already done.
Another way could be to set the operating density to zero at the start. But you'd have to re-run the case. |
October 28, 2018, 09:32 |
#3 | |
Hamed Abdul Majeed
Rep Power: 14 |
Why didn't fluent define such a pressure variable...to avoid any extra effort. Because without it the pressures don't make practical sense! |
October 29, 2018, 09:31 |
#4 | |
Lucky
Rep Power: 66 |
So why isn't there another variable that does contain the hydrostatic part? In this situation, you'd use the reference density approach which Fluent does provide. So yes it is developer laziness. |
gravity |
How to activate the gravity effect in Laminar flow | kr660170 | FLUENT | 2 | July 3, 2018 10:50 |
Effect of Gravity | ali-st | FLUENT | 0 | July 1, 2018 03:25 |
Density effect with gravity not working | halowine | FLUENT | 2 | September 17, 2017 16:50 |
VOF and gravity effect | sirpolar | Fluent Multiphase | 1 | August 3, 2015 08:15 |
Gravity Effect.... | Dev | FLUENT | 1 | May 29, 2015 12:06 |
