Rotating pipe analysis
Like Tree3Likes
  • 1 Post By Duke711
  • 1 Post By Duke711
  • 1 Post By LuckyTran
Old   October 23, 2018, 20:16
Default Rotating pipe analysis
Hamed Abdul Majeed
hamed.majeed is on a distinguished road
Water flow in a pipe from P1 to P2, where P1>P2. The pipe is rotating about the axis shown in figure. How to analyze such a problem!
In addition to the frictional loses, the flow has to overcome the centrifugal force!
what is the chemical name of alum
hamed.majeed is offline   Reply With Quote
Old   October 23, 2018, 21:10
Duke711 is on a distinguished road
With mesh motion under cell zone conditions
hamed.majeed likes this.
Duke711 is offline   Reply With Quote
Old   October 27, 2018, 15:22
Hamed Abdul Majeed
Can't I define it as a moving reference frame case? Thank you.
Old   October 28, 2018, 14:21
No, moving frame are only moves the coodinate system -> sliding wall, no effect of the mass moment of inertia from the fluid.
Old   October 29, 2018, 09:18
Lucky
Even easier is to just go to boundary conditions and make it a moving wall. No need for the mesh to move.
Moving reference frame does not provide the motion. But you probably should use a moving reference frame anyway for post-processing purposes so that you do not need to decompose the velocity field into the rotating part and relative part.
HHK likes this.
Car external aerodynamic with wheel spinning issue hokhay FloEFD, FloWorks & FloTHERM 2 August 18, 2016 05:23
Rotating cylinder analysis in Fluent sercan85 ANSYS 0 August 15, 2016 07:03
Pipe Flow Analysis akshayygarg FLUENT 3 March 4, 2011 09:57
stress analysis of a rotating beam(wind blade) Cheyannne ANSYS 0 October 19, 2009 18:06
Rotating machine analysis Hans Main CFD Forum 1 November 19, 2002 07:49
