how to stop solving flow equations foe a specific cell zone
Like Tree1Likes
  • 1 Post By LuckyTran
Old   October 17, 2018, 07:11
Default how to stop solving flow equations foe a specific cell zone
taba
mojtaba.safdari.ms@gmail. is on a distinguished road
i have a transient problem. in which a turbulence air flow passes around a phase change material which is wrapped around a heater. i just want to solve energy equation for my phase change material zone because it takes too long for computation if i solve flow equations for this part and also i get floating point in seconds after pcm starts melting.
i wonder if s/o could help me.
thank you
mojtaba.safdari.ms@gmail. is offline   Reply With Quote
Old   October 17, 2018, 10:35
Lucky
You can't skip solving only the flow equations in only 1 cell zone. You can however, skip solving the flow equations across any/all zones. Just go solution=>controls=>equations (or just solution controls in earlier versions), it's the same place where you specify under-relaxation factors. You can deselect Flow (you should also deselect turbulence) and keep only the energy selected.
Old   October 17, 2018, 10:44
taba
So what should i do?I always get floating point error simulating melting process. i cant skip flow eqs. because the heat transfer between pcm and air flow is important for me.Do you have any suggestion for me?
Old   October 18, 2018, 00:43
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
most likely the problem comes from material properties
best regards
AlexanderZ is offline   Reply With Quote
Old   November 18, 2022, 07:41
Default Freezing flow solution in only one fluid cell zone
Yogesh
yogesh03y is on a distinguished road
Hi, did you figure out a way to solve this issue? I am solving a similar problem. I'm trying to simulate a transient heat discharge from a phase change material (PCM) to air flowing in a channel below it. I am interested in the temperature dependent variations in the flow field. So the flow solution of air is required. For the PCM, only the temperature and liquid fraction are of interest.
Thanks!
yogesh03y is offline   Reply With Quote
melting, melting&solidification, phase change material
Problem with chtMultiregionFoam radiation boundary condition baran_foam OpenFOAM Running, Solving & CFD 10 December 17, 2019 18:36
Suppress twoPhaseEulerFoam energy AlmostSurelyRob OpenFOAM Running, Solving & CFD 33 September 25, 2018 18:45
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 06:24
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 19:07
