October 3, 2018, 14:31 |
Convergence of Mass Flow Rate
Artem
Rep Power: 13 |
October 4, 2018, 16:05 |
Rep Power: 11 |
It's actually really easy to do this. Simply go to the Tree-Solution-Monitors and double-click Convergence Conditions. This will bring up a new window. Click the "Add" button, and est the Report Definition to your Mass Flow Rate Report Definition. I'd double-check on what some of the options within the window means, just for completeness, though.
October 5, 2018, 08:52 |
#3 | |
Artem
Rep Power: 13 |
I thought about it, but the MFR has not only positive value, but also negative. And in Convergence Conditions I can determine only condition when my value below some value. Well all negative values will satisfy that condition too. But it will be wrong. |
October 5, 2018, 11:21 |
#4 | |
Lucky
Rep Power: 66 |
In newer versions of Fluent it is straightforward to setup this type of asymptotic convergence check for lots of variables. It's v16 it is cryptic and you have fewer options, but doable since you already have a working monitor.
The stop criterion is not a threshold, it is a type of normalized absolute variation. If m(i) is the monitor, the variance after 1,2,...p iterations is: R(1) = abs(m(n)-m(n-1))/m(n) R(2) = abs(m(n)-m(n-2))/m(n) R(p) = abs(m(n)-m(n-p))/m(n) It checks to make sure all the R's are less than the stop criteria over p iterations. You should note that the variation is normalized the latest value of the monitor. Which means that you need to specify the stop criterion as a % variation rather than as absolute threshold. An example is you could use the the lift coefficient as a convergence monitor (which should converge to some finite positive number). |
October 5, 2018, 13:25 |
Rep Power: 11 |
Looks like Lucky beat me to the punch. Go ahead and give it a try and check back in to make sure it works.
October 8, 2018, 07:12 |
Artem
Rep Power: 13 |
LuckyTran, Thank you very much for your help. It really helped me.
convergence, fluent, mfr, udf |
Discrete Phase Model, outlet mass flow rate does not fit | edu_aero | FLUENT | 29 | February 3, 2020 09:38 |
Shape Optimization Problem of Mass Flow Rate | ggc1991 | SU2 Shape Design | 1 | December 1, 2016 21:24 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 02:27 |
DPM total mass flow rate | yow | FLUENT | 0 | July 17, 2015 13:01 |
Mass Flow Rate Error | jallison | FLUENT | 1 | May 16, 2011 17:22 |
