Setting porous jump BC on interface of two bodies
Like Tree1Likes
  • 1 Post By LuckyTran
Old   September 25, 2018, 14:50
Default Setting porous jump BC on interface of two bodies
Vaelyn is on a distinguished road
How do I set the porous jump condition on the interface of two bodies generated by Boolean tool on Designmodeler? When I try to set it to the interface of both only the "interface" boundary condition is displayed by Fluent
Edit: although there is a way to define an "interior" (volume domain) as porous jump
Vaelyn is offline   Reply With Quote
Old   September 25, 2018, 18:43
Lucky
Originally Posted by Vaelyn View Post
Edit: although there is a way to define a "interior" (volume domain) as porous jump
There is a cell zone condition (a volume) and boundary condition. There is no interior in cell zone condition. In boundary condition, interior is actually a surface. Forget that this surface is of type interior or not (pretend it is type banana), if it is the right surface then you can just change it to porous jump.
You can only create interfaces across different cell zones.
Vaelyn likes this.
boundary condition, fluent, porous jump bc
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Strange behaviour: Ethanol solution flow on channel with interface to porous domain khariel CFX 6 December 11, 2014 18:08
[Commercial meshers] Porous Jump creation problem mulfal OpenFOAM Meshing & Mesh Conversion 4 December 9, 2013 12:59
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 21:09
