September 22, 2018, 14:06 |
multiphase flow
Tonoy Mondol
Rep Power: 8 |
I am going to simulate solar still using nanofluid. upper a glass surface and constant temp. lower is a wood surface of constant temp.VOF model is used.now my question is: what is the phase interaction I will provide? water to vapor and vapor to water or only the first? and also is there any option to put latent heat of vaporization in ANSYS? and if I add nanoparticle with water then is it possible to do with VOF? or mixture model is necessary?
September 24, 2018, 09:16 |
#2 | |
Bhargav Bharathan
Rep Power: 11 |
To use VOF you need to have 2 or more immiscible fluids. Check out the link below: https://www.sharcnet.ca/Software/Flu...ug/node881.htm -BB |
September 24, 2018, 13:55 |
#3 | |
Mehdi Asghari
Rep Power: 16 |
Also , you need the implementation of phase change in VOF model. There are a lot of papers & references for this purpose. Good luck. M.Asghari |
September 25, 2018, 11:49 |
#4 | |
Tonoy Mondol
Rep Power: 8 |
please give me your mail id then I will give you the problem description and you help me if you can |
September 25, 2018, 11:51 |
#5 | |
Tonoy Mondol
Rep Power: 8 |
my mail - tonoymondol@gmail.com |
evaporation condensation, latent heat, multiphase flow, vof |
About Some Concepts:Laminar flow, turbulent flow, steady flow and time-dependent flow | Jing | Main CFD Forum | 8 | October 5, 2018 17:02 |
multiphase flow ,mass and volume fraction imbalance | sope111 | CFX | 16 | September 3, 2018 00:10 |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Multiphase flow in a pipe with a CHT | wissal | CFX | 4 | June 12, 2017 12:15 |
Capillary pressure in multiphase flow in porous media | Lalit | FLUENT | 0 | March 21, 2013 01:24 |
