Courant number calculation and min. grid size |
September 3, 2018, 05:22 |
Soheil
Rep Power: 12 |
For calculating the Courant number (Co = U*timeStep/meshSize), minimun edge length is needed. My 3D Mesh is generated in Ansys meshing and it's all Tetrahedron (V=a^3/6*(2)^0.5). Is it OK to make an approximation of the smallest grid length by the volume of the cell, which is volume of a regular tetrahedron? Fluent generates the "minimum volume (m3)". Thanks for any advice, |
September 4, 2018, 13:11 |
Micael
Rep Power: 18 |
Create a custom field functions so you can visualize courant number field. It will give you a better picture to judge if your courant number is good.
this text command might work or need a bit adaption: Code:
define/custom-field-functions/define "courant-nb-gas" "velocity_magnitude*delta_time<rd>/cell_volume^(1/3)" |
September 5, 2018, 12:50 |
Lucky
Rep Power: 66 |
For tetrahedrons it is not right/wrong to use the cell volume (I would do it and throw in a factor of safety). The faces are not oriented in any particular direction with the flow. Even if you knew the minimum edge length, you wouldn't know it's oriented with respect to x,y,z coordinates and you still don't know the u,v,w velocity components. So in general you should run a few test cases to confirm the courant number that you get from your mesh. The best you can do is guess.
There already is a courant number field in Fluent. You don't need to create a custom field function. But this doesn't help you predict anything without meshing and simulating a case first. |
courant number, fluent |
multiphaseEulerFoam high Courant number | Frenk_T | OpenFOAM | 5 | November 24, 2016 03:23 |
twoPhaseEulerFoam fvOptions for alpha | lavdwall | OpenFOAM Running, Solving & CFD | 8 | October 19, 2015 09:57 |
Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 05:36 |
Courant Number | NiBa | FLUENT | 0 | November 18, 2014 16:45 |
Problems with Courant number (LaunderGibsonTurbulence Model) | sven | OpenFOAM | 3 | August 10, 2009 03:12 |
