Darma Yuda
Rep Power: 9 ![]() |
Hello everyone,
I know this topic has been discussed a few times in this forum. But I don't really understand. I am trying to do some CFD Simulation for a small hydrodynamic coupling/fluid coupling. My Modell 1. The fluid is oil (incompressible) and has constant Rho and viscousity (no heat transfer) 2. I am using k-epsilon, realizable, scalable wall function 3. For every simulation, I am giving a different rotational velocity to my Pump-cell zone and my Turbine-cellzone. So I can meassure the Torque for every slip condition (0-100%). The rotational velocity is about 5000-8000 rpm. 4. The diameter of the coupling is about 66 mm. And the total width is 20 mm. 5. The reference pressure: 0 Pa 6. No gravitational force. Problem: At certain point (for example Pump: 8000 rpm, Turbine: 0 rpm, it means Slip 100%), the static preassure (volume average) is around -1,8 bar. This doesn't make any sense, right? Although, the total pressure=static pressure+dynamic pressure is fulfilled. 1. After reading a bit in this forum. I have found, that it can happen sometimes in Fluent for incompressible fluid. The negative static pressure only show the difference of the pressure. But I don't really understand why? Can anyone explain to me a bit? 2. Another posibility is a cavitation is expected at this condition to happen. How should I prove this phenomenon? Another feedback would be much appreciated. If you need any information, please don't hesitate to let me know. Thank you in advance. Best regards, Darma |
For incompressible flow, only the pressure gradient rather than the pressure itself appears in the governing equation, which means that you can add any constant to the pressure field without affecting the governing equation. The arbitrariness of such constant is removed by any Dirichlet-type boundary conditions for pressure or by the operating pressure if no such boundary exists.
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Cavitation (a phase change phenomenon) can't occur for a constant density fluid so you will never get this phenomenon. You need to change your model so that it is at least possible first.
Darma Yuda
Hello blackmask,
Thank you very much for your response. Ah I see. So that means, my initial pressure in this model shouldn‘t be 0 bar (gauge)? And if I add some higher pressure for the operating pressure, I would get the same delta pressure. Am I correct? Best regards, Darma |
Darma Yuda
Hello LuckyTran,
Thank you very much for your response. Do we need multiphase for the cavitation? At first I thought, that a negative static pressure is a sign of a cavitation and if we want to look furthermore, we need to activate the multiphase. Also, we can not identify a cavitation just by looking at the pressure itself without activating the multiphase? Best regards Darma |
By initial pressure do you mean operating pressure? It does not matter if you set the operating pressure to zero. In fact such a value is not used unless there is no Dirichlet-type pressure boundary condition in your case setup, which is rare in common practice. You only need to interpret pressure as "pressure difference". For example, say you have a pressure outlet where the static pressure is zero pa, and there is a point where pressure is -10000 Pa, then it should be interpreted as the pressure difference from such a point to the outlet is -10000Pa.
Darma Yuda
Hello blackmask,
Thank you very much for your reply. Yes I mean operating pressure. Sorry, my mistake. So I've got several question. 1. I've tried to set the operating pressure (the one in boundary condition) and the reference pressure (the one in reference value) to 1 bar. And the value of the pressure I got is the same like the one with 0 bar. I thought if I change the ref pressure to 1 bar, the fluent will show us the pressure in absolut instead of a gauge pressure. Is it because my model just doesn't have Dirichlet type boundary pressure? If that's the case, what should I do, if I want Fluent to show absolute pressure instead of gauge pressure? 2. Regarding your example, static pressure I got on the result is about -1,8 bar. And by pressure difference here you mean the pressure difference before the simulation and after the simulation, right? And how do I know, which point is my reference point here? Best regards, Darma |
#8 | ||
#9 | |
Darma Yuda
Hello blackmask,
Thank you very much for your reply. Then I would like to ask further. Quote:
#10 |
hydrodynamic coupling, static pressure |
negative static pressure !!!! | Barbara | FLUENT | 15 | April 7, 2018 14:30 |
Negative absolute pressure in core vortex | clod | FLUENT | 1 | March 11, 2015 05:33 |
channelFoam for a 3D pipe | AlmostSurelyRob | OpenFOAM | 3 | June 24, 2011 13:06 |
defining a term for a domain using DEFINE_ADJUST | MASOUD | Fluent UDF and Scheme Programming | 1 | September 24, 2010 05:08 |
Hydrostatic pressure in 2-phase flow modeling (long) | DS & HB | Main CFD Forum | 0 | January 8, 2000 15:00 |
