Is this project converged? (Imbalance mass flow rate between outlets and inlets!)
Like Tree1Likes
  • 1 Post By blackmask
Old   August 30, 2018, 09:48
Question Is this project converged? (Imbalance mass flow rate between outlets and inlets!)
Roh
Roh is on a distinguished road
Guys
I'm simulating an axisymetric nozzle and trying to measure its thrust. So tried to measure mass flow rate but it doesn't make any sense to me because suming the mass flow rate of Inlets and outlets are not in balance(its summing is not zero). Here is a screenshot of the mass flow rate.
As you can see Net Result is not zero. why?
I was thinking that maybe my problem is not converged completely. Here is a screenshot of the Residuals of this timestep:
Isn't this project converged?
Roh is offline   Reply With Quote
Old   August 30, 2018, 21:31
blackmask will become famous soon enough
The major inlet flow is from one of the boundary named "outlet2". If this boundary is actually one of the outlet boundary type, you might consider changing it to one of the inlet boundaries, or you must set the reversing flow parameters carefully.
Roh likes this.
blackmask is offline   Reply With Quote
Old   August 31, 2018, 00:56
Roh
"outlet2" and "outlet1" are "Pressure farfield" and "outlet3" is "Pressure outlet". To prevent of revers flow I chose these boundries. Here is a screenshot of setting for "outlet1" and "outlet2"
And here is a screenshot of setting for "outlet3"
I chose this magnitude for Intensity and Viscosity ratio because the nozzle flow is injecting to the air and I don't expect any reverse flow. What do you think about this setting?
Mass imbalance problem in multiphase water and steam CFX case Antech CFX 1 October 26, 2020 05:03
2 inlets, 2 outlets. Assessment of flow rate ratio. Jiricbeng CFX 9 May 22, 2018 06:29
Y-pipe mumtaz ersan FloEFD, FloWorks & FloTHERM 4 January 15, 2015 17:19
rate flow FLUENT rayan24 FLUENT 3 July 25, 2013 04:26
sos! How to define the flow rate of outflow BC? zjm FLUENT 0 June 4, 2004 10:12
