c_udmi returns zero when called in another udf
Like Tree3Likes
  • 1 Post By blackmask
Old   August 29, 2018, 12:03
Default c_udmi returns zero when called in another udf
Jannis
JannisSif is on a distinguished road
Hi!
I am trying to create a udf which finds the average temperature at the outlet of the domain and then applies it to the inlet (increased by 7.58). I wrote the following udf but in the DEFINE_PROFILE the c_udmi returns zero and thus the F_PROFILE(f,t,nv) gets equal to 7.58 constantly......can someone help please??
DEFINE_EXECUTE_AT_END(average_exit_temp)
face_t f;
cell_t c0;
Domain *d=Get_Domain(1);
Thread *t=Lookup_Thread(d,8), *t0;
real vol=0, tavg=0, temp=0, vol_tot=0;
t0=THREAD_T0(t);
begin_f_loop(f,t)
c0=F_C0(f,t);
vol=C_VOLUME(c0,t0);
vol_tot+=vol;
temp=C_T(c0,t0);
tavg+=temp*vol;
end_f_loop(f,t)
tavg/=vol_tot;
begin_f_loop(f,t)
c0=F_C0(f,t);
C_UDMI(c0,t,0)= tavg;
printf("\n Average temperature is: %g\n",C_UDMI(c0,t,0));
end_f_loop(f,t)
DEFINE_PROFILE(inlet_temperature, t, nv)
face_t f;
Thread *t0;
cell_t c0;
real tavg;
t0=THREAD_T0(t);
begin_f_loop(f,t)
c0=F_C0(f,t);
F_PROFILE(f,t,nv)= C_UDMI(c0,t0,0) + 7.58;
printf("\n Inlet temperature is: %g\n",F_PROFILE(f,t,nv));
end_f_loop(f,t)
JannisSif is offline   Reply With Quote
Old   August 29, 2018, 21:12
blackmask will become famous soon enough
You just need to store one value "tavg", what do you need a "UDM" for? You can simply declare "tavg" in the file scope.
The "c0" in "DEFINE_PROFILE" is the cell index adjacent to inlet boundary, which has no overlap with cell index adjacent to outlet boundary. Suppose there is a grid with 100*100 cells and is number from top left to bottom right. The inlet and outlet boundary are located at the left and right ends, respectively. Then in the "DEFINE_EXECUTE_AT_END" you assigned values for cells with index ranging 9900 to 9999, then in the "DEFINE_PROFILE" you obtain values from cells with index ranging 0 to 99.
blackmask is offline   Reply With Quote
Old   August 30, 2018, 04:38
Jannis
Hi blackmask and thank you very much for the reply. I am very new to udfs and so I am a little confused....
So as far as I understood from what you wrote, in my case, I could use the following code, wright?
#include "udf.h"
real tavg=280.;
face_t f;
cell_t c0;
real vol=0, temp=0, vol_tot=0;
t0=THREAD_T0(t);
begin_f_loop(f,t)
c0=F_C0(f,t);
vol_tot+=vol;
temp=C_T(c0,t0);
tavg+=temp*vol;
end_f_loop(f,t)
tavg/=vol_tot;
face_t f;
begin_f_loop(f,t)
F_PROFILE(f,t,nv)= tavg + 7.58;
end_f_loop(f,t)
The problem is though that although it is interpreted without a problem, when I start the calculation I get a "floating poitn axception error". Also the "printf" I used says that "Inlet temperature is: inf"......what could be the problem?
Thank you very much for your time!
Old   August 30, 2018, 06:23
You should check whether the thread is empty or the sum of volume is non-zero. What is the output of the code below?
#include "udf.h"
real tavg=280.0;
    face_t f;
    cell_t c0;
    t0=THREAD_T0(t);
    Message("number of faces: %d\n", THREAD_N_ELEMENTS(t));
    begin_f_loop(f,t)
        c0 = F_C0(f,t);
        vol = C_VOLUME(c0,t0);
        vol_tot += vol;
        temp = C_T(c0,t0);
        tavg += temp*vol;
    end_f_loop(f,t);
    Message("sum of volumes: %g\n", vol_tot);
    tavg /= vol_tot;
DEFINE_PROFILE(inlet_temperature1, t, nv)
    face_t f;
    begin_f_loop(f,t)
    end_f_loop(f,t)
Old   August 30, 2018, 06:42
Jannis
So I run the code (actually changed the "message" with "printf" because I could not interpret it) and it printed this:
number of faces: 0
sum of volumes: 0
number of faces: 0
sum of volumes: 0
number of faces: 0
sum of volumes: 0
number of faces: 6
sum of volumes: 1.33696e-07
number of faces: 0
sum of volumes: 0
Old   August 30, 2018, 06:46
The thread id (8) could be wrong. Please check.
Old   August 30, 2018, 06:48
Jannis
I just checked, it is correct (8) for the outlet of the domain.....
Old   August 30, 2018, 07:28
You can use the following code (just paste them to the the fluent TUI, i.e., the console below the graphics window)
(rp-var-define 'jos-thread-id-list () 'list #f)
(rpsetvar 'jos-thread-id-list ())
(for-each (lambda (t) (rpsetvar 'jos-thread-id-list (list-add
(rpgetvar 'jos-thread-id-list) (thread-id t))))
(get-all-threads))
(rp-var-define 'jos-thread-name-list () 'list #f)
(rpsetvar 'jos-thread-name-list ())
(for-each (lambda (t) (rpsetvar 'jos-thread-name-list (list-add
(rpgetvar 'jos-thread-name-list) (thread-name t))))
(get-all-threads))
to get the list of zone names and their ids. What is the output?
Old   August 30, 2018, 08:13
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
number of faces: 0
sum of volumes: 0
number of faces: 0
sum of volumes: 0
number of faces: 0
sum of volumes: 0
number of faces: 6
number of faces: 0
sum of volumes: 0
why do you have 5 output messages?
Are you using 5 cores?
best regards
AlexanderZ is offline   Reply With Quote
Old   August 30, 2018, 08:18
Jannis
The output is:
jos-thread-id-list
> jos-thread-id-list
> (6 3 14 2 8 7 13 1 9 10 11 12 5)
> adapt/ file/ solve/
adjoint/ mesh/ surface/
close-fluent parallel/ views/
define/ plot/
display/ report/
> adapt/ file/ solve/
define/ plot/
display/ report/
> (zone_wall part_4-surface_body interior-zone_wall-shadow interior-zone_wall outlet inlet symmetry interior-part_4-surface_body wall_tank-part_4-surface_body-zone_wall wall_tank-zone_wall plates-part_4-surface_body plates-zone_wall wall_tank-part_4-surface_body-zone_wall-shadow)
Old   August 30, 2018, 08:19
Jannis
best regards
Hi Alexander,
I am running on 4 cores (not sure why I have 5 messages....)
thank you.
Old   August 30, 2018, 09:42
Did not see that coming. Please try the following code:
#include "udf.h"
real tavg=280.0;
    face_t f;
    cell_t c0;
    t0=THREAD_T0(t);
    tavg = 0.0;
#if RP_NODE || !PARALLEL
    begin_f_loop(f,t)
        c0 = F_C0(f,t);
        vol_tot += vol;
        temp = C_T(c0,t0);
        tavg += temp*vol;
    end_f_loop(f,t);
    tavg = PRF_GRSUM1(tavg);
    vol_tot = PRF_GRSUM1(vol_tot);
    tavg /= vol_tot;
    Message("processor: %d,tavg: %g\n", myid, vol_tot);
#endif
    face_t f;
    begin_f_loop(f,t)
    end_f_loop(f,t)
#endif
JannisSif likes this.
Old   August 30, 2018, 09:52
Jannis
Thank you so much for your help! I tried the code you sent me but I got an error "MPT_gssum1: no function prototype"
Old   August 30, 2018, 10:59
The error does not occur if you can use compiled UDF. Otherwise it might need a work-around.
Old   August 30, 2018, 11:09
Jannis
Yes you are absolutely right! It worked fine!!! Thank you so much!
So just to understand exactly what happened, the problem was that each core was calculating a different value? Or something else?
Old   August 30, 2018, 21:23
The solver processes are composed of one host node plus n (n=4 in your case) computing nodes. The host process definitely have no data of your outlet thread, so it will always result in 0./0. (i.e., FPE error you have encountered). Depending on the mesh partition, the computing node may or may not have data of your outlet thread, so it may cause FPE. Besides, the (temperature*volume) and (volume) should be summed from all computing nodes and then compute the average value, which is done with PRF_GRSUM1.
Old   August 31, 2018, 04:05
Jannis
Thank you very much for your time and help!! Have a nice day!
Best regards,
Jannis
c_udmi, fluent - udf, udf
UDF: How to load data from an external file into a vector EmiS Fluent UDF and Scheme Programming 17 January 14, 2019 02:55
dynamic contact angle udf returns no value to solver shiraz_man67 Fluent UDF and Scheme Programming 5 July 3, 2018 15:51
Help with unsteady calculation with source/sink UDF RobV Fluent UDF and Scheme Programming 3 March 10, 2016 04:45
Source Term UDF VS Porous Media Model pchoopanya Fluent UDF and Scheme Programming 1 August 28, 2013 07:12
Help me to check my UDF Liufeng_ustb Fluent UDF and Scheme Programming 2 May 7, 2013 11:25
