Reynolds Number
Like Tree1Likes
  • 1 Post By blackmask
Old   August 24, 2018, 16:35
Default Reynolds Number
Ujjwal Mohanty
ujjwalmohanty is on a distinguished road
For Re = 100
1) Characteristic Length = 2m; Density = 1 kg/m^3; Viscosity = 1 kg/m-s; Velocity = 50 m/s
2) Characteristic Length = 2m; Density = 1 kg/m^3; Viscosity = 0.02 kg/m-s; Velocity = 1 m/s
Will both the cases give similar results like Cd, Cl, Velocity and Pressure Contours etc. ?
ujjwalmohanty is offline   Reply With Quote
Old   August 24, 2018, 23:35
blackmask will become famous soon enough
For incompressible flow, they should result in identical non-dimensionalized quantities. For compressible flow, as far as Mach number is low, they should give similar results.
ujjwalmohanty likes this.
blackmask is offline   Reply With Quote
fluent 16, renolds number
decomposePar no field transfert Jeanp OpenFOAM Pre-Processing 3 June 18, 2022 13:01
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
[OpenFOAM.org] OF2.3.1 + OS13.2 - Trying to use the dummy Pstream library aylalisa OpenFOAM Installation 23 June 15, 2015 15:49
Cluster ID's not contiguous in compute-nodes domain. ??? Shogan FLUENT 1 May 28, 2014 16:03
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
