August 7, 2018, 13:19 |
Injection in Fluent and DPM
Soheil
Rep Power: 12 |
The goal of my current fluent work is to simulate the mixing of aqueous sucrose solution [viscousity of ~15.43 mPa.S] and ethanol [viscousity of ~1.1 mPa.S] inside a stirred tank. Water solution is already inside the tank to a specific height and ethanol must be "somehow" added to the system. I have decided to use Euler-Lagrange multiphase flow approach [Discrete Phase Model in fluent] for this case, as it has the injection option for defining the injection point/location. It seems like DPM is the only choise for the purpose of this case. I appreciate any advice, help and insight regarding this. Is this approach correct? Thanks. |
August 7, 2018, 15:48 |
Lucky
Rep Power: 66 |
Should also be doable with Eulerian VOF formulation or full Euler-Euler approach.
By "add" do you mean there is a drop of sugar that you want to see dissolve? Or do you want a steady stream? An initial drop is "added" in the solution initialization. To do the initial drop, you can use the mark cells for refinement in a region (a sphere for example). This creates a cell register. Then you can patch those marked cells with the volume-fraction for the sucrose phase. Yet an even more simple approach might not involve multiphase models, this doesn't feel like a multiphase problem to me. Use a species transport model. |
August 8, 2018, 03:01 |
Soheil
Rep Power: 12 |
Thanks.
The issue is finding a way for that "initial drop" with a specified velocity, diameter, etc. I will try to learn doing it through cell register, according to your advice. I think I was a bit vague in describing the overall objective of the case. The idea is simulating Antisolvent Crystallization, where another solvent (e.g. ethanol) is added to the existing solution (saturated water-sucrose mixture). Materials do not matter for now; it is just two liquids with different viscosities. The main obstacles are: 1. Doing the injection/drop in fluent without changing the geometry (like to implement an inlet), AND 2. Selection of appropriate model (multiphase, like mixture model or maybe species transport). As in the lab, we can assume a glass pipet that injects liquid into a tank with constant flowrate at different locations (attached picture). Best Regards, Soheil Last edited by soheil_r7; August 8, 2018 at 10:16. |
crystallization, euler-lagrange, mixing, multiphase flow, stirred tank |
DPM - Define cone injection in Ansys fluent | bhat_nikhil | FLUENT | 0 | October 31, 2017 03:42 |
the DPM injection problem in Fluent 15.0 | wht2019 | FLUENT | 1 | October 27, 2016 06:38 |
FLUENT DPM unsteady particle time step VS injection time step | wv1216 | FLUENT | 0 | May 19, 2016 12:47 |
Injection file problem with FLUENT DPM | nav | FLUENT | 0 | November 16, 2013 20:03 |
DPM injection mass flow rate | kingpots | ANSYS | 0 | November 22, 2012 12:12 |
