Mesh Interfaces option is disabled in Fluent
Like Tree1Likes
  • 1 Post By AlexanderZ
Old   August 5, 2018, 04:30
Default Mesh Interfaces option is disabled in Fluent
Lokesh Dhake
Loki is on a distinguished road
I am working on an assembly with more than 2 parts which have some connections with each other as you can check in the image.
But, whenever I'm opening the Fluent, the mesh interfaces option is not accessible.
I am using Ansys 14.0, Please suggest any solution as early as possible
Loki is offline   Reply With Quote
Old   August 5, 2018, 22:46
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
Go to design modeler and check there how many parts of model you have.
I guess you have 1 part with all bodies inside, but for your case you should put each detail of assemble to separated part.
hope this will help you
best regards
Loki likes this.
AlexanderZ is offline   Reply With Quote
Old   August 6, 2018, 01:13
Lokesh Dhake
best regards
Thanks AlexanderZ for the suggestion. I checked the DM, there are no. of different parts not a single part as you can check in the attachment. Please ignore the suppressed parts.
Moreover, is this problem due to Enclosure featured I used?
Old   August 6, 2018, 04:18
Taiwan,new north city
Rajaero is on a distinguished road
Suggestions :
1. try to use space claim instead of design modeler
2. try to do volume extract method (you can see some videos on you tube)
3. try to select share option under properties in space claim
4. check overlap interfaces in mesh (right click connections and select check overlap connections)
please try these and let me know if it worked.
Thanks...
Rajaero is offline   Reply With Quote
Old   August 6, 2018, 16:39
Lucky
A lot of options get disabled when you use the workbench instead of standalone Fluent. Check in Fluent if you have the needed interfaces already, if not then you need to take care of it in the workbench.
connections, contacts, fluent, mesh, mesh interfaces
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Simulation of a single bubble with a VOF-method Suzzn CFX 21 January 29, 2018 01:58
Difficulty in calculating angular velocity of Savonius turbine simulation alfaruk CFX 14 March 17, 2017 07:08
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
