Problem with interpreted UDF with UDM calculation |
July 4, 2018, 05:25 |
Marco
Rep Power: 8 |
EDIT: i sucessfully compiled all my UDF. I had to do some work on my envrionment paths...
But still the same problem, it crashes on initialization with the UDF defining the pressure inlet with mass as criterium Hello everybody! I am Modelling a Vacuum assisted resin transfer moulding (VRTM) of a porous medium. My Simulation works fine, 5 UDF (viscosity, timestep, porosity) are running in interpreted mode. (cant run compiled, get the libudf error constantly) But i simply cant write a UDF that computes the mass in the volume, saves it as a UDM so i can then use it for a pressure inlet UDF. Here are the 2 UDF's i have written for the mass: DEFINE_PROFILE(pressure_profile, t, i) { real x[ND_ND]; /* this will hold the position vector */ real y; real mass; face_t f; real time = CURRENT_TIME; Domain *domain; Thread *ct; cell_t c; domain = Get_Domain(1); begin_f_loop(f, t) { F_CENTROID(x, f, t); y = x[1]; if (C_UDMI(c, t, 0) < 0.5) F_PROFILE(f, t, i) = 101325; else F_PROFILE(f, t, i) = 350; } end_f_loop(f, t) } DEFINE_ADJUST(mass, domain) { real mass; Thread *t; cell_t c; Domain *domain; domain = Get_Domain(1); begin_c_loop(c, t) { mass += C_R(c, t) * C_VOLUME(c, t); } end_c_loop(c, t) C_UDMI(c, t, 0) = mass; } This UDF does work and runs in FLUENT, but it seems it does not save the correct value of mass, as the pressure does not go down after 0,5 kg aquired. I thank all of you beforehand and hope u can help me with this problem. Last edited by Kabador; July 4, 2018 at 11:18. |
July 4, 2018, 19:59 |
Rep Power: 18 |
First, the DEFINE_ADJUST macro is called after the DEFINE_PROFILE macro. Second, the user-defined memory (UDM) are defined for each cell and modified with C_UDMI(c,t,i) where c is the cell in thread t and i represents the UDM index. Did you want the mass of the complete cell zone, or of the neighbouring (local) mass? For the former, you could use a loop within the DEFINE_PROFILE macro (take care with parallel processing with multiple partitions in the same cell thread), and for the latter you could use the neighbouring cell macro F_C0(f,t) within the face loop.
July 6, 2018, 16:12 |
Marco
Rep Power: 8 |
Thanks for the answer! Sorry i am a noob in programming.
Yes i want to: 1. compute the mass in the whole cell zone, 2. then check if it aquired enough mass 3. then edit the pressure so the flow stops But i cant get it to run. DEFINE_PROFILE(pressure_profile, t, i) { face_t f; cell_t c; real mass; begin_c_loop(c, t) { mass += C_R(c, t) * C_VOLUME(c, t); } end_c_loop(c, t) begin_f_loop(f, t) { if (mass < 0.5) F_PROFILE(f, t, i) = 101325; else F_PROFILE(f, t, i) = 350; } end_f_loop(f, t) } |
July 6, 2018, 20:21 |
Rep Power: 18 |
You're on the right track. A couple of things, the variable mass should be initialised with zero (otherwise the value is whatever was already in memory; garbage).
real mass = 0.0; Code:
... Domain *domain = Get_Domain(1); /* domain pointer; the domain ID is one unless there are multiple phases */ int id_interior_cell_zone = 1; /* the ID shown in the cell zone list */ Thread *t_interior_cell_zone = Lookup_Thread(domain, id_interior_cell_zone); ... begin_c_loop(c,t_interior_cell_zone) { ... } end_c_loop(c,t_interior_cell_zone) ... Note: if you are running with parallel processors, i.e. the domain is partitioned, then you would need to employ the relevant macros for communicating between processors to find the overall mass in the domain rather than the mass for each processor. See the chapter on "Parallel Considerations" in the UDF manual for reference. |
July 8, 2018, 04:36 |
Marco
Rep Power: 8 |
Thanks for your help again!
With your suggestions and another forum post on parallelisation i made it work. Here is the Code for other people who might have the same problems: DEFINE_EXECUTE_AT_END(calcm) { #if !RP_HOST cell_t c; Domain *domain = Get_Domain(1); int id_interior_cell_zone = 3; Thread *t_interior_cell_zone = Lookup_Thread(domain, id_interior_cell_zone); begin_c_loop(c, t_interior_cell_zone) { mass += C_R(c, t_interior_cell_zone) * C_VOLUME(c, t_interior_cell_zone); } end_c_loop(c, t_interior_cell_zone) mass = PRF_GRSUM1(mass); #endif //Host printf("Masse: %g\n", mass); //prints the mass in each node on console fflush(stdout); } DEFINE_PROFILE(pressure_profile, t, i) { face_t f; cell_t c; begin_f_loop(f, t) { if (mass < 0.8) F_PROFILE(f, t, i) = 101325; else F_PROFILE(f, t, i) = 350; } end_f_loop(f, t) } |
fluent, udf, udm, vof, vof simulation |
Help with unsteady calculation with source/sink UDF | RobV | FLUENT | 1 | November 13, 2016 06:44 |
Help with unsteady calculation with source/sink UDF | RobV | Fluent UDF and Scheme Programming | 3 | March 10, 2016 04:45 |
Problem with interpreted UDF | cp_jef | Fluent UDF and Scheme Programming | 0 | August 2, 2011 01:17 |
UDF using problem, error happens-heip!! | Michael | FLUENT | 1 | December 9, 2008 08:51 |
parallel UDF problem | kerem | FLUENT | 2 | June 20, 2006 07:56 |
