Matt Ridzon
Rep Power: 12 ![]() |
Sorry, novice question here...
I built a small model in v18.2 Fluent within Workbench. How do I export the CAS and DAT files from the Fluent session to share with a colleague? I see Export options under the File menu, but the UI seems clunky/broken and won't let me navigate to a new directory and if I instead just hit OK, it thinks I'm trying to overwrite the existing files in the Workbench directory. I can't imagine such a simple task would be this hard. ![]() Thanks in advance! M Ridzon |
Tarantino
Rep Power: 13 ![]() |
Hi!
did you find any solution to this? |
Matt Ridzon
Yes, but not to any credit of this forum. This forum is quite dead in terms of prompt, usable feedback folks can receive, which is quite unfortunate. I'm still a novice, but not as much as I was when the post was made. As such, I've learned a few things between then and now, to include the answer to this question. And as I suspected, the answer was trivial. I assume dozens of more experienced users here would have been able to easily answer the question, but never took the time to do so. I learned that you can merely choose File > Export > Case & Data to save out the files so they can be shared with a colleague. The GUI is a little clunky though and you need to manually key in a browser location to save the files to, since the GUI doesn't auto-update as you browse therein. It will save out "unzipped" case and data files; i.e., the file extension will be *.cas and *.dat, as opposed to the usual zipped formats, *.cas.gz and *.dat.gz. That tiny detail doesn't really matter though, in terms of what I wanted to accomplish. Alternatively, I learned that you can merely go to the Workbench directory (\\dp0\FFF\Fluent) to manually copy/paste the case and data files.
As obvious as the solution sounds, the answer was not known to me, and so that's why I thought this forum would be helpful to learn. Sadly, I was wrong though. To my delight though, I eventually figured it out on my own. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Probably because you asked a question about Workbench in the Fluent forum where more users use Fluent exclusively outside of the workbench environment. Because how to write a .cas and .dat file is as trivial as opening the same .cas and .dat file (if you're only using Fluent). Btw the usual format is .cas and .dat (not gnuzipepd). If you know these things already. If you're at the level that you are writing gnuzipped files, it's really odd that you don't know how to write a .cas & .dat file. Looking back, I think it's better than you spent the time in Workbench/Fluent to learn it on your own.
Also this is not a support/service Forum on Ansys or any software. You should be expressing your discontent on the Ansys customer support website if these are your feelings. Here your mileage will vary as we do not have service guarantees here, only (sometimes) goodwill. |
#5 | ||||
Matt Ridzon
Lucky
I'm simply telling you that this particular sub-forum predates Ansys and Ansys workbench. Asking a workbench question in the Ansys section would have probably gotten you a better response. And asking the question in Ansys customer support definitely would have gotten you a better response since there you are entitled to an answer. A lot of users here only use Fluent and have never used workbench and probably never will ever use workbench.
It's also really hard to answer an odd inquiry. All the time there are questions of how to read a data file that was previously saved. Just do it is not a helpful response... Answering with just do it normally gets the person trying to help flamed. Not answering, gets complaints that they're not answering (which you just aptly proved). So to summarize, don't be salty that your question went unanswered and diss the same community that you wish could have done you better. |
[OpenFOAM.org] Compiling OpenFOAM 5.0 on the Titan Supercomputer | wildfire230 | OpenFOAM Installation | 20 | May 6, 2020 07:30 |
A CFX-POST error (ver 14.5.7) | wangyflp88 | CFX | 2 | July 22, 2017 00:17 |
[General] Reading Fluent gzip-compressed files to ParaView | larsschwarzer | ParaView | 4 | August 8, 2014 04:12 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Hidden info in cas and dat files | Dan | FLUENT | 0 | June 7, 2006 07:40 |
