Mass diffusivity Error(zero mass diffusivity)
Like Tree2Likes
  • 1 Post By Nishant_Sharma
Old   June 10, 2018, 04:47
Default Mass diffusivity Error(zero mass diffusivity)
Anomymous
Nishant_Sharma is on a distinguished road
Hi all,
I am using a Species Transport model in simulating a fuel cell problem, and I am defining the diffusivities of all the species by using UDF, although the fluent is showing an error,
Warning: Mass_Diffusivity: invalid (zero) diffusivity.
Please check material properties.
Also, when I tried it on another PC, no such error is shown, but in my previous pc, it shows the error and the simulation won't run. Can anyone please tell how to remove this error.
Thank you
ramakant likes this.
Nishant_Sharma is offline   Reply With Quote
Old   June 11, 2018, 08:20
Refik
rewol is on a distinguished road
When i need to define mass diffusivities through UDF, i usually make all diffusivities of all species equal to 10e-12 at first even though mixture is composed of a single specie initially.(For instance, before combustion)
rewol is offline   Reply With Quote
Old   June 11, 2018, 08:59
Anomymous
Thanks rewol for your reply, but I have defined the diffusivities of all the species already, still it is showing this error
Old   June 11, 2018, 09:26
Refik
Did you use mixture-averaged multicomponent diffusivities ?
The reason i am asking is because, when calculating D_i,m for example, in case of pure specie, D_i,m might still be zero.
Old   June 14, 2018, 02:32
Anomymous
Hi rewol,
Now I have figured out what was the problem, there are some extra species in my model, which cannot be removed, and since I have defined the diffusivities of species whaich I have created by myself, the diffusivities of other species are not defined, which is creating the problem.
souza.emer likes this.
Old   November 28, 2018, 13:35
Default mixture mass diffusivity udf help
nmk539 is on a distinguished road
sir how to write udf for mixture mass diffusivity ie Dij diffusion of species i in j actually i am simulating pem fuel cell i found in paper authors are using binary mixture diffusion coefficient how to write udf
equation is as follow
P*Dij=a*(T/sqrt(TciTcj))^b*(PciPcj)^1/3*(TciTcj)^5/12*(1/Mi+1/Mj)^0.5
sir please share udf if you have made it already
thanks in advance
nmk539 is offline   Reply With Quote
Inconsistencies in reading .dat file during run time in new injection model Scram_1 OpenFOAM 0 March 23, 2018 23:29
DPMFoam - Serious Error --particle-laden flow in simple geometric config benz25 OpenFOAM Running, Solving & CFD 27 December 19, 2017 21:47
Disable Mass Diffusivity and Enable UDS Diffusivity antoinel FLUENT 0 July 26, 2017 18:27
Mass diffusivity problem chuan820316 FLUENT 0 February 23, 2017 04:52
Pressure Outlet Targeted Mass Flow Rate LuckyTran FLUENT 1 November 23, 2016 11:40
