CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM
Like Tree1Likes
  • 1 Post By Blue
Old   May 17, 2018, 12:23
Default CFD Fluent tutorial - Shell and tube heat exchanger - PROBLEM
Tom
tom96 is on a distinguished road
Hi everyone,
I was trying to replicate an online tutorial on Shell and Tube Heat Exchangers found in Youtube. The link is provided with this post.
https://www.youtube.com/watch?v=NPJImYibx48
I followed all the steps of the tutorial an run the simulation with no problem. However the results that I have obtained are different than the ones of the tutorial (see image)
The temperature profile doesn't seem fully developed in my case (as it is all blue instead of red/yellow). Does anyone has any idea of where I might have made a mistake?
My ideas:
1. Maybe I didn't run the simulation for enough iterations? (around 200 iterations)
2. Maybe I have missed one of the steps of the tutorial? (I went through the steps and everything seems fine to me.)
3. The geometry I've used is slightly different from the one of the tutorial - the hot air inlet and outlet are in the opposite position compared to the one of the tutorial (but I've obtained this geometry from the website of the youtuber.)
4. Maybe I have created the "Named Sections" in the wrong way, for example I have named my hot air inlet at the bottom right of the geometry whereas I believe that it is at the top right of the geometry in the tutorial. Moreover I've included gravity in my simulation which may impede the hot fluid to reach the top left of the geometry. I think this makes sense, what do you think?
PS: Has anyone successfully performed this tutorial?
Would really appreciate if someone could help me with this
Thanks in advance!
Regards,
tom96 is offline   Reply With Quote
Old   May 21, 2018, 01:24
Blue's Avatar
Blue is on a distinguished road
You may forget setting inlet/outlet temperature in BC.
tom96 likes this.
Blue is offline   Reply With Quote
Regarding change of tube material of shell and tube heat exchanger kkj1234 FLUENT 0 October 16, 2016 23:39
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
shell and tube heat exchanger... ganesh chakravarthi CFX 3 July 6, 2015 19:44
CFD analysis of Shell & Tube Heat Exchanger vdpatel06 FLUENT 0 November 5, 2014 03:57
How to simulate 3D shell and Tube heat Exchanger san FLUENT 2 February 22, 2006 06:44
