May 16, 2018, 09:33 |
Simulation of supercritical flow in fluent
Nitesh Kumar
Rep Power: 10 |
Hi all,
I am trying to simulate flow of supercritical Co2 in microchannel using fluent. it's a 2D simulation and it consists of a inlet, outlet and two walls. Inlet velocity-0.01 m/s Inlet pressure- 7.5 MPa, Inlet Temperture- 304.2K, I have chosen velocity inlet as inlet boundary condition and pressure outlet as outlet boundary condition. But i don't know value of pressure at outlet and what should be the value of operating pressure? Thank You! |
May 17, 2018, 00:18 |
Lucky
Rep Power: 66 |
The operating pressure can be set to anything as long as you remember that all pressures in Fluent are gauge pressures, so adjust your settings accordingly.
The only solution which admits only upstream conditions is when the flow is super-sonic. Otherwise, you need a downstream condition and this probably means giving up the pressure at the inlet constraint. Or you can iterate the outlet pressure until you get the desired inlet pressure (there's no built-in tools to do this). |
September 20, 2019, 06:24 |
Property Variation of Supercritical Flow
#3 | |
Thamilmani M
Rep Power: 8 |
How did you implement the property variations for the supercritical CO2 in FLuent? Did you have measured values of properties over the temperature range? Thank you
Always Thedal |
bubble diameter definition in multi phase flow boiling simulation FLUENT | Abishek | FLUENT | 13 | July 1, 2019 12:12 |
Surface Source - Fixed Temperature? | robtheslob | FloEFD, FloWorks & FloTHERM | 18 | May 12, 2017 02:28 |
Comparison between Solidworks Flow Simulation and Ansys Fluent | Bruce828 | Main CFD Forum | 5 | February 23, 2013 10:13 |
What the differences flow equation of Fluent 6.3 and Fluent 12.1 | opehterinar81 | FLUENT | 0 | August 19, 2011 11:55 |
Simulation of a flow through porous mesh in fluent | G.Vijaya Rama Reddy | FLUENT | 0 | September 14, 2006 00:35 |
