Calculating average total pressure over a surface |
May 16, 2018, 00:51 |
Vinayak-
Rep Power: 8 |
Hello everyone,
I am analyzing an electro-hydraulic valve (flow driven analysis), for which I need to calculate the average total pressure required at the inlet surface. I was able to plot a contour, which shows the minimum and maximum values of total pressure at the selected surface, but I need the average of those pressure values. The function calculator provides me with average static pressure at the selected surface. Is there a way in ANSYS Fluent 19.0, to calculate average total pressure over a surface?
Thanks, Vinayak |
May 16, 2018, 01:19 |
Lucky
Rep Power: 66 |
Isn't it straightforward?
When you go to report => surface integral => whatever average you want , choose pressure as the field variable and there should be options for static, dynamic, & total pressure. |
May 16, 2018, 02:02 |
Vinayak-
Rep Power: 8 |
Thanks LuckyTran for this quick resolution!
Thanks, Vinayak |
ansys fluent 19.0, total pressure, valve simulation |
total pressure change in a pipe flow | Im | FLUENT | 5 | February 23, 2017 09:55 |
Static or Total Pressure Inlet Boundary, Understanding problem | Overdue | CFX | 13 | August 4, 2016 08:25 |
Gate valve flow simulations... | nikesh | FloEFD, FloWorks & FloTHERM | 5 | January 28, 2014 02:31 |
[General] Calculating average pressure | julien.decharentenay | ParaView | 1 | August 19, 2013 08:50 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
