Divergence detected in AMG solver: k,epsilon,Increasing relaxation sweep? |
May 9, 2018, 05:29 |
BHOLU KUMAR
Rep Power: 8 |
we're simulation mixing of jets problem in ANSYS (Fluent solver) for Mach 1.86 jets where jets are issuing from convergent-divergent nozzle into free atmosphere. The 2D domain is extended from C-D nozzle to free atmosphere.
The main highlights of simulation are 1. Density based solver (air is compressible): steady, axisymmetric 2. Ideal gas, Sutherland Viscosity 3. k-e realizable turbulence model 4. Solution method formulation : explicit 5. Default courant number = 5 6. Checked solution initialization for : Std., hybrid, fmg But I'm getting Divergence in AMG solver with following error messege # Divergence detected in AMG solver: Coupled -> Decreasing coarsening group size! # Divergence detected in AMG solver: Coupled -> Increasing relaxation sweeps! # You may try the enhanced divergence recovery with (rpsetvar 'amg/protective-enhanced? #t) Divergence detected - temporarily reducing Courant number to 0.5 and trying again... Divergence detected - temporarily reducing Courant number to 0.05 and trying again... Divergence detected - temporarily reducing Courant number to 0.005 and trying again... Divergence detected - temporarily reducing Courant number to 0.0005 and trying again... Divergence detected - temporarily reducing Courant number to 5e-05 and trying again... Internal error at line 1603 in file 'dbns\rp_mstage.c' on Node 0. Please help some one help me. |
May 14, 2018, 02:41 |
Aravinth
change the convergence value for k and epsilon in residual and solve it !!
September 25, 2020, 03:24 |
Same issue!!
#3 | |
Heri T
Rep Power: 6 |
i am facing same issue for same problem can you post the solution? |
Error: Divergence detected in AMG solver | siri | FLUENT | 8 | March 12, 2018 18:08 |
Divergence detected in AMG solver: temperature | R4RAHUL | FLUENT | 6 | September 16, 2014 18:44 |
Divergence detected in AMG solver: pressure correction | xinquanzhoucn | FLUENT | 5 | July 21, 2014 05:49 |
Divergence detected in AMG solver: pressure coupled | n.jithin.1991 | FLUENT | 6 | January 5, 2014 12:43 |
Quarter Burner mesh with periosic condition | SamCanuck | FLUENT | 2 | August 31, 2011 12:34 |
