how to model humidity or moisture within fluent?
Like Tree1Likes
  • 1 Post By e_cfd
Old   May 6, 2018, 23:32
Default how to model humidity or moisture within fluent?
jian
ljt19960221 is on a distinguished road
hi,
Does anybody know how to model humidity in fluent? I understand that the species transport has to be implemented but it is not clear how to set up the model.
I have a humidifier here and I want to know the RH of the surrounding air and moisture level of a wall.
temperature is around 40 degree Celsius, RH is around 40 - 60%.
I need some guide please.
Thank you very muchhh.
ljt19960221 is offline   Reply With Quote
Old   May 7, 2018, 09:13
ehsan
e_cfd is on a distinguished road
Hi Jian,
You need to define a mixture through the Species model and define proper species in the material menu (i.e. Air and water vapor). Moreover, you need to assign a proper mass fraction of water vapor based on RH and T at the inlet(s) (easily can read from the psychrometric chart).
PJTsai likes this.
e_cfd is offline   Reply With Quote
Old   May 11, 2018, 04:51
jian
Thanks for your guide. I have tried it and it worked.
But I wondering why the relative humidity on the wall is all the same as I thought it should be different humidity on different session of the wall.
Old   May 11, 2018, 04:55
ehsan
If you share a figure illustrating your computational domain and boundary conditions maybe I can help to find out the problem.
Old   May 29, 2018, 07:29
miracle_cyq is on a distinguished road
I'm doing a humidity field analysis of the atomization of the nozzle. The atomization field is a cylinder with a length of 1 m and a diameter of 0.1 m, with walls on both sides and an outlet on the bottom. I would like to ask, how to set this boundary condition, and how to add humidity? I currently use the combined output model and the DPM model, but as a result, the mass fraction of water has always been zero. I'm confused, please. Thank you.
miracle_cyq is offline   Reply With Quote
Old   February 8, 2020, 02:58
Default moisture with dpm method
edris3320 is on a distinguished road
hi
anyone know how to use moisture with dpm method? i have particles that want to dry them.
thank alot
edris3320 is offline   Reply With Quote
Old   February 9, 2020, 16:36
Default Tutorial available
vinerm's Avatar
Vinerm
vinerm will become famous soon enough
I suppose Fluent has a standard tutorial for spray drying. Just search for it.
Regards,
Vinerm
PM to be used if and only if you do not want something to be shared publicly. PM is considered to be of the least priority.
vinerm is offline   Reply With Quote
Old   February 8, 2021, 15:42
Sara
sara moradi is on a distinguished road
Originally Posted by edris3320 View Post
hi
thank alot
Hi edris,
I'm looking for moisture content in fluent too. Did you figure out how obtain it?
sara moradi is offline   Reply With Quote
Old   February 8, 2021, 15:50
Sara
yes, but it does't mention to moisture content.
humidity, moisture
Seeking Macroscopic Particle Model in Fluent bzhang7 FLUENT 3 June 25, 2022 18:54
Integration of a Custom C++ Model into FLUENT Syed Haider FLUENT 2 March 7, 2018 00:37
Ansys Fluent K-Epsilon Model gshankarau FLUENT 0 September 23, 2016 06:59
Fluent :- turbulence Model prince_pahariaa FLUENT 9 May 20, 2016 04:41
How to create a 3Ds Car Model importing to FLUENT? spysunny Main CFD Forum 1 January 11, 2012 00:40
