Sprity Acharya
Rep Power: 8 ![]() |
Hey everybody!
I have been working on gas flow through a pipe in Fluent. I vary the diameter of the pipe and compare the flow rates in this project. I was using air as the working material and got results. Now I switched to argon and fluent displays divergence detected in AMG solver: temperature. Can anybody give me hints on why it happens? I am using “ideal gas” as density and running the k-omega SST model. Thank you for any suggestions given. |
#2 | |
Kushal Puri
Rep Power: 12 ![]() |
If it is velocity inlet try to run with mass flow inlet. |
Sprity Acharya
Hi!
I am using pressure inlet condition. It is a simulation of gas atomization process. I was able to get results till 4 mm of tube diameter. But i get divergence from 5 mm. thanks. |
Lucky
Rep Power: 66 ![]() ![]() ![]() |
Check your boundary conditions. If you're using a turbulence model then also make sure you update the turbulent length scale or hydraulic diameter at inlets.
Check also your initial conditions. Don't respond with "i used calculate from." |
#5 | |
Sprity Acharya
My boundary conditions are working perfectly for air. When switched to argon, Fluent gives me results for smaller diameter. |
Anonymous
What is the type of mesh you are using? Bad tets sometimes cause peaks and lows in temperature etc.
Try using constant density first, converge the flow then enable ideal gas density. Reducing relaxation factor for energy may also help. |
argon, divergence amg solver, k-omega sst model, temperature |
Custom Thermophysical Properties | wsmith02 | OpenFOAM | 4 | June 1, 2023 14:30 |
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
[swak4Foam] funkyDoCalc with OF2.3 massflow | NiFl | OpenFOAM Community Contributions | 14 | November 25, 2020 03:30 |
fluent divergence for no reason | sufjanst | FLUENT | 2 | March 23, 2016 16:08 |
[swak4Foam] Problem installing swak_2.x for OpenFoam-2.4.0 | towanda | OpenFOAM Community Contributions | 6 | September 5, 2015 21:03 |
