Periodic Boundary conditions for turbulent flow in ANSYS fluent? |
April 20, 2018, 03:41 |
Dev Fons
Rep Power: 8 |
I am keen to know how to simulate periodic boundary conditions in Fleunt for turbulent pipe flow. I understand turbulent flow is not steady and periodic implies steady but is it possible to get RANs or avergaed quantities for turbulent flow for this case. I know for normal boundary conditions the turbulent intensity can be specified at the inlet and outlet but this option is not available in k-epsilon model. In addition, anyone have pointers on the method to ensure convergence. My mesh is really fine with nearl 200000 elements but it takes ages to run and the residuals don't converge below tolerance. I am simulating flow in a wavy channel. |
April 20, 2018, 12:27 |
Lucky
Rep Power: 66 |
Periodic does not imply steady.
The point of Reynolds-averaging is so you get a laminar-like equation after you take the time average. There are no "velocity fluctuations" in RANS. Remember what you solve for in RANS is the mean flow, not the instantaneous flow. There are not explicit inlet BC's for periodic boundary condition option, because it's periodic. If you have an inlet/outlet then you can specify the turbulence intensity and so on, but you do not have an inlet or an outlet, you have a periodic BC. 200 000 is (frankly) a baby mesh. It shouldn't take ages to run. |
April 20, 2018, 13:25 |
#3 | |
Dev Fons
Rep Power: 8 |
I have been using SIMPLE thus far for methods. |
ansys, converge cfd, fluent, periodic bc, turbulence |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 06:45 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 07:40 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 19:02 |
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field | xiexing | CFX | 3 | March 29, 2017 11:00 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 06:15 |
