Sequence for animation disappear after closing Fluent |
Rep Power: 0 ![]() |
Hi all,
More a technical than theoretical problem, I work transient state and need to do videos of my simulation. So (Fluent 16.2) I use solution>calculation activities>solution animations and I define 1 sequence animation. https://imgur.com/wkQMgom It works but the problem is if I close Fluent then reopen it with the case and data saved the sequence disappear... https://imgur.com/bQ421Gi Does anyone have the same problem and know how to solve it ? Thanks a lot! |
ehsan
Rep Power: 11 ![]() |
In animation definition you have to change the storage type to HSF file. |
It doesn't change whatever the storage type I choose :-s
Every time I create a sequence, run my simulation for a few time steps, then I manage to animate the sequence and to write a video. Then I write case/data and close Fluent. But after when I open Fluent again and load case/data my sequence created disappeared :-/ Or is it possible to load the .cxa file created somewhere? |
Aniket Dalvi
Rep Power: 6 ![]() |
Hey, did you solve this issue? I am facing the same.
animation, fluent 16.2, sequence |
heat transfer with RANS wall function, over a flat plate (validation with fluent) | bruce | OpenFOAM Running, Solving & CFD | 6 | January 20, 2017 06:22 |
Fluent crash on writing data file after thousand iterations | Chuck87 | FLUENT | 0 | September 2, 2015 16:17 |
Loading Animation Sequence in FLUENT Produces Blank Screen | SeanQuallen | FLUENT | 0 | February 17, 2012 09:56 |
Fluent 6.3 32bit vs Fluent 12.0 64bit | ibex7 | FLUENT | 7 | April 18, 2011 02:44 |
Fluent 12.0 is worst then Fluent 6.2 | herntan | FLUENT | 5 | December 14, 2009 02:57 |
