How can I inject N2 into air?
Like Tree1Likes
  • 1 Post By e_cfd
Old   March 18, 2018, 01:40
Question How can I inject N2 into air?
Roh
Roh is on a distinguished road
Guys
I'm trying to inject N2 into air using a nozzle. here is a sketch of my domain.
At nozzle inlet, we are suppossed to inject N2 into air as the ambient fluid. How can I do this?
Roh is offline   Reply With Quote
Old   March 19, 2018, 04:32
ehsan
e_cfd is on a distinguished road
I think you can use Species model and define a mixture of N2 and air then at the inlet you can define the mass fraction of N2.
e_cfd is offline   Reply With Quote
Old   March 19, 2018, 06:43
Post
Roh
Good idea, I was thinking about it and tried it but "Species" tab is not enable in the boundary condition. here is a screenshot of my setting:
Old   March 19, 2018, 06:51
ehsan
Dear Roh,
I suggest you read the tutorial for the species model and everything would be clear to you. However, if you active the species model you have to go to the material and there you have to choose N2 and air as the mixture components (N2 should be the first component!!). Then you can go to the boundary conditions and from the species tab of the inlet boundary condition, you would be able to assign proper values to the mass fraction of each species.
If the species tab is not active, check the cell zone. you have to change the fluid to the mixture.
I hope it helps.
Roh likes this.
Old   March 19, 2018, 07:44
Roh
Thank you.
It's enabled, now. Going for a run. god bless you
Air at High Pressure cfd seeker FLUENT 2 September 30, 2013 15:58
Is it possible to integrate air through a system with mixture of air and water? Hale OpenFOAM Post-Processing 1 September 30, 2013 09:57
air distribution and heat transfer wasim_kassel FLUENT 0 June 24, 2013 12:12
Air to Air Heat Exchanger visser1975 FLUENT 2 November 10, 2012 14:34
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
