Water expansion in closed domain
Like Tree1Likes
  • 1 Post By Audrius
Old   March 17, 2018, 07:37
Default Water expansion in closed domain
Audrius
Audrius is on a distinguished road
Dear colleagues,
I have question for You. I have been analyzing water expansion in 2D closed domain (0.2 m x 0.2 m). The left wall of square are 370 K, the right wall is 277.15 K, other walls are isolated. Initial water temperature is 277.15 K. Initial pressure 101325 Pa. I use this setup:
Pressure based solver
Transient time solver
Gravity -9.81
Operating pressure 101325
Operating density 0
Piso for pressure-velocity coupling
PRESTO! for pressure spatial discretization
Etc….
For water properties, I have used this setup:
1. Piecewice-linear for density; constant properties for other parameters. Conclusion: velocity field looks normal, residuals reach convergence criteria, and density changes are visible. However, there is no pressure rise in the domain.
2. Piecewise-linear for all water properties. Conclusion: results are the same as in the 1 case.
3. Compressible-liquid for water density; constant properties for other parameters. Conclusion unrealistic velocity, temperature, density, pressure fields and etc. There is no pressure rise in the domain.
How to create the setup, that pressure in the domain will be function of water volume/density?
Please, find the attached case file of my task.
Thank You.
Kind regards,
Audrius
sankalpjain likes this.
Audrius is offline   Reply With Quote
Old   April 9, 2018, 06:56
Question Temperature dependent density. ??
sankalp jain
sankalpjain is on a distinguished road
Can you please tell me which piecewise polynomial you used for the variation of density of water. I am doing a geometrically similar case in 3D. I actually have closed 3d tubes instead of square.
I am unable to get the velocity field in my case. Maybe because I have provided the density as constant. Can you please tell me how to provide a temperature dependent density.
sankalpjain is offline   Reply With Quote
Old   April 9, 2018, 07:06
sankalp jain
Old   April 10, 2018, 02:28
Audrius
Piecewise-linear
Sudden increase the residual of Maxwell's equations hsezsz CFX 2 October 13, 2016 07:58
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Pressure distribution on a wall darazsbence CFX 17 October 6, 2015 11:38
Floating point exception: Zero divide liladhar CFX 11 December 16, 2013 05:07
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 08:59
